Hi,
So the nimrod that had my truck before me obviously cracked his old pass door glass and put in a plexiglass piece he cut.
I now have a new piece of glass but need help with the removal of the old plexiglass. its the same size if not smaller as the factory glass.
i have the plexiglass detached from the regulator channel (2 bolts) and unbolted the glass run on the right hand side of the door (one bolt) (looking at inside of door).
i also removed the metal and felt strip that runs around the entire door that was previously pushed in (? is it called weather strip)
but i still cant get it out. tired to rotate it too. no dice.
any ideas?
do i have to remove the ENTIRE regulator mechanism?
thanks!
H
any ideas?
thanks!
H
