I'll be doing a HG and valve job soon.
Anyone in the Tulsa area you would recommend for these big Toyota 6's?
I had Lucito's do my 2F block, crank, and head for the FJ-60. He did a good job. He also did the second head after I cracked the first one. I would recommend him.
Yes it is.Is this the Uncle Meat from OKS?
Jonny
Lucitos is off Mingo just West of 55th. I took my crank, block, and head along with my new pistons and valve guide seals. I did all the legwork getting freeze plugs from Cruiser Dan in NM and piston/rings from Man-a-fre. The old Toyota engines are not something these guys see all the time and probably don't have contacts to get parts. I put it all together myself.
Tom is a one man shop so if you want it tomorrow - might find somewhere else.
Some of the other guys are using another shop. They say he is cheaper. I will try and find out which one.
PS - I am on OKS also - same name.
Uncle Meat - are you looking for a machine shop or someone to do all of the work? Not sure if I answered your question.
Jonny,
I need someone to do the machine work on the head of my 1996.
Valve guides, grind valves, and adjust valve lash (shims).
I'm going to do the head gasket as PM soon.
Would like to find someone who knows Toyota's
-Kevin
