Hi everyone. Rear wash not spraying water. I can hear it working but no water coming out. Any ideas? Thanks
I have tried a pin in the nozzle and did notice a little bubble of fluid in the nozzle but no flowIf you don't use it often it takes a bit of time for the water to make it to the rear of the truck. We're taking 5-10 seconds from my experience.
Jim
Nope. Didn’t work. No spray. Reckon blockage in the nozzle itself but won’t know how to remove..Any luck? Because I have the same problem. Of course, I can simply try it myself, eh?
It depends on which way you rotate the switch. IIRC, holding it clockwise only gets fluid. If you click through intermittent, then full on, then you can hold it and get fluid and wiper.I'm not getting any fluid to the back, but the wiper isn't moving when I try to spray either. The wiper works on the other settings. Should the wiper be moving when I try to spray?
