Rear window in 80 LC (1 Viewer)
KSV
Down under. Melbourne.
Is anyone can point me to link with explanation how I can take off (and put back!) rear window from 80 LC. I am talking about side rear window in cargo area. Mine LC is a basic model and therefore has solid (i.e. non-sliding) rear window.
Thanks a lot for any input.
The Factory Repair Manual has two procedures for this. One involves using a new gasket and the other involves reusing the old gasket. If you want to use a new gasket the removal is easy. You pretty much cut the glass out of the gasket from the outside. To keep the gasket you pop the window out. The Manual shows a taped screw driver being used from the inside to pry the gasket off of the body. The latter method would be the easiest to mess up on.
I would wait to look at the diagrams before I decided to do this.
