Hello everyone! Hopefully someone can help me debug this vibration problem. The other day, I found a pretty sizable nail in my left rear tire. After inspecting all of the tires, I also found another one in the left front. But back to the rear. I attempted to do what should have been a relatively easy task of replacing the flat tire with the spare. However, I could not get the ug nuts off and ended up breaking one, with another having that same "cross threaded" feel. I didn't want to risk breaking another because I went through that experience about 3 weeks ago with the right side (ended up breaking one and having the shop break another two). Luckily I had already ordered the studs and the lug nuts and brought them in when I had the job done.
I was not so lucky this time. I ended up having to drive very slowly to the nearest station (.5 miles) to put in enough air to get me home. There was no visible damage to the tire. Today, I drove the car with about 15 to 18 lbs of pressure to a parts store to buy tire plugs and then back home where I plugged the tire on the car.
The strange thing is, now I'm getting serious vibrations from the rear end at highway speeds, so much that even my 4 year old twins are giving me a look as if there're saying "hey dont you feel that?!?!" lol
any suggestions? I really dont want to have to put it up on a rack for inspection because it had absolute no rear vibration problem before this event. The car has 170,000 miles and has performed flawlessly for the last 10 years aside from starter rebuild, timing belts, TPS Sensor, 1 ignition pack, etc.. pretty standard stuff! i keep all of the fluids changed and everything serviced on or before schedule, with Penzoil synthetic and mobil one.
