rear driver door needed
None...
But what happened that you need to replace it. You might try an autobody repair shop, they might be able to help you out. We have a body panel shop here in Indy but I can not recall the name...sorry!
Robert
None...
Robert
big tree got in the way with stub of a branch out of my sight in the side mirror...impossible to pull out . Thought someone might know of one in a wrecking yard somewhere.
you install everything your self...did you need to take off the fuel tank to resize it...did you need to shorten the drive shaft???
I was Jim's (Inchworm) prototype truck, so they installed everything. I did the gas tank. I warmed the front of the tank up and reshaped the front corner so the crawler and tcase would fit. We had a driveline shop lengthen the front and shorten the rear drive shafts.
