Real time LSPV help...
Highland, UT
I've searched and read several threads about moving the LSPV after installing a lift, but most of them refer to the adjuster arm being mounted to the frame. Mine is mounted to the rear diff. If you are supposed to move the LSPV down when mounted to the frame, should I move mine up on the diff? It seems to make more sense to move down. Below is a pic (my apologies for the red Moab mud...consider it a primer for you CM folks) Thanks in advance for your input.
hmmm..., you got the weird double bend on that connecting rod too! So maybe mine is indeed OK after all. (notwithstanding the wannabe :censor: comedians in the other thread....)
anyway, yes, the valve body attached to the frame is the part that's easy to move up and down a tad.
