Inglewood, CA – PML designed an extra capacity cover for the front differentials on*2003 to 2012 Ram 2500 and Ram 3500 trucks. This cover is a bolt on replacement for the*stock cover on the American Axle Manufacturing (AAM) 9 1/4 inch ring gear differential*used in these trucks. Because of many clearance problems with steering, U-bolts, […]
The post Ram 2500 & 3500 Trucks Can Have Extra Capacity and Clearance with New PML Front Cover appeared first on RockCrawler 4x4 and Offroad Magazine.
Related posts:
Because of many clearance problems with steering, U-bolts, and suspension , PML*maintained a low profile with partial fins with this cover. Starting in about 2008, Dodge*added a U-bolt to the front end design that would contact larger aftermarket covers when*at the limit of the steering. This U-bolt was retrofitted on early year trucks during service*visits. The suspension on Megacabs would also contact a larger cover when the truck was*loaded. PML designed this cover to avoid these problems.
Features of the new PML front cover are;
Related posts:
Link
Related posts:
- Rancho® Introduces Level It Suspension Kit for Dodge Ram 2500/3500 Trucks
- High Clearance Dual Steering Stabilizer
- ICON RAM 2500/3500 Coilover Conversion Systems
- Low profile requires no modifications to U-bolt for steering clearance
- 1/2 quart extra oil capacity for cooler temperatures
- Sand-cast aluminum with raised fins
- 3/16-inch thick wall construction to add strength to differential housing
- 3/8-inch thick gasket flange
- Boss for a temperature sensor
- Drain hole for easy oil changes
- Hardware provided, including magnetic drain plug
- Available in three finishes, natural (as cast), powder coated, polished
Related posts:
Link
