radiator cover
Homewood(B'ham), AL
I recently found out that I am missing my radiator cover. I thought about just replacing it but then i thought could i just take the steering stabilizer out, use the holes in the frame where it origanoly was and keep going to also protect the pulley sys [SIZE]
You can delete it yourself. I dont get what youre talking about with the stabilizer, if youre talking about flipping it around in the original mounts to move it backwards to keep things away from the pulleys, you cant do that, the bolts holding it in are taperend and will only seat one way. Get the skidplate, im sure you can find it cheap and it helps to shape the airflow through the radiator.
ok i am talking about taking the steering stabilizer mount off, and have a metal plate going from the front of the frame to the frame where there is a hole, putting a ventilation hole for the radiator and then putting the steering stabilizer back on. does any one know if this would work or would the air flow be too messed up?
