This site may earn a commission from merchant affiliate links, including eBay, Amazon, Skimlinks, and others.
rock scientist..
Staff member
s-Moderator
Moderator
One 14 bolt one D60 .
Both 5.13's
The 14 bolt is new and the 60 is used.
"Hallucinations are bad enough. But after awhile you learn to cope with things like seeing your dead grandmother crawling up your leg with a knife in her teeth. Most acid fanciers can handle this sort of thing. But nobody can handle that other trip-the possibility that any freak with $1.98 can walk into the Circus-Circus and suddenly appear in the sky over downtown Las Vegas twelve times the size of God, howling anything that comes into his head. No, this is not a good town for psychedelic drugs."
60 looks good, 14 B is off, my rear end guy always runs a piece of notebook paper thru, and looks at the pattern.....want me to send ya' some more 4x4 websites you can ask this question on??????
Seen it 3 places already..
.bitch
Butch
Top two wrong. Bottom one good.
Ed
Ed
Agreed. On the top two, assuming backlash is set in spec, the pinion needs to be shimmed closer to the ring gear. I'd add about .020" and then run another pattern.
rock scientist..
Staff member
s-Moderator
Moderator
Miker, the ist two were the 14 bolt. it only had a .020 shim in it. I replaced the 20 with a 10 and got a significantly better pattern..
backlash was set at .007
New backlash is at .010
I can't argue with success but those first two patterns (14 bolt) are indicating the pinion is too shallow.
rock scientist..
Staff member
s-Moderator
Moderator
On a 14 bolt you remove shims to get the pinion closer to the ring gear..
