John in Utah
Another update from the BaT seller. I copied and pasted below:
Hi friends – I took the BJ42 to Peter Merriam today with Merriam Automotive in Duluth, GA for a very quick inspection of the items mentioned. Peter has been working on Land Cruisers since 1975, and you’ll see his name pop up at ih8mud.com from time to time.
Although he didn’t have availability for a full inspection, he did comment on the following items that you all asked about:
1. Fluid on oil pan – small leak from oil pan gasket, and oil is being blown around the oil pan and front driveshaft from air out of the blowby tube. He said the rear main seal looks fine.
2. Transfer case – yes, seals are leaking, but far from uncommon and certainly repairable.
3. Long cold start – the batteries are from 2011 and are due for a replacement. New batteries will likely correct the cold start issue.
4. General rust – the most significant rust is in the driver’s footwell, and rust in other areas is generally minor. (additional pictures of requested areas are being uploaded).
Other general comments – don’t forget that all J40 trucks are at least 35 years old! With that in perspective, this truck is in good condition. The vast majority of the truck has been spared from major rust, the 3B engine is still running like its normal bulletproof self, and the 5 speed transmission still feels great and shifts smoothly. This is an original BJ42 (rather than a converted FJ), and it will really be worth something to a true Cruiser-enthusiast who can appreciate how rare and unique it is to have a true BJ around here!
@handcar yes, the rear seats do have the support bars (shown in new picture being uploaded).
Seller mentions "air" coming out the blowby tube. Couldn't that be an indication of compression getting past the rings and pushing oil out the blowby tube?
Some blow by is normal on an old IDI motor.
I believe him about the batteries and the cold start. If it had a compression issue I would expect it to miss or idle rough for a few seconds (like mine does
