Pulstar Plugs?
MCAS Miramar
Im getting ready to change out my spark plugs and was going to go with the NKG's when the guy at the shop told me to look into pulstars...apparently they guarantee a gain of at least 5 hp from these plugs and they run 25 bucks a piece, they say that an independent lab tested them. It almost sounds too good to be true thought, I wanted to know if anyone had used them in their FJ or not...If not what other types of plugs is everyone using?
Im getting ready to change out my spark plugs and was going to go with the NKG's when the guy at the shop told me to look into pulstars...apparently they guarantee a gain of at least 5 hp from these plugs and they run 25 bucks a piece, they say that an independent lab tested them. It almost sounds too good to be true...
Think you answered your own question.
I am pretty old, and used to make a living as a mechanic. Miracle spark plugs have been around since the Model T. All the ones I've ever seen are snake oil, but YMMV.
Before the days of modern computerized ignition from the factory, you could get a few HP by putting in a big-ass coil and opening your spark plug gaps way up, but that is pretty much already done for you now stock.
Denso K20HR-U11
thanks for the input
If true, is 5HP at 6,500 rpm worth $150 to you? Not me. You wouldn't even feel it.
Now if I gained 3 mpg, maybe. But that would be impossible with just a sparkplug swap. Stick with the Denso's or NGK's. They are cheap and will not let you down.
"It ain't broke"
DEWFPO
Ya i went with the NGK Iridium's that what my buddy runs in his race truck so i figured it was a good bet...Id rather spend that money on something else anyways, plus after reading more on their website it said the pulstars were for stock engines only and couldnt be used on modified engines...so that was out.
It's a bunch of crap. If it sounds to good to be true, it usually is. Stick with the Denso's IMO.
I just installed these in my wife's2008 Subaru Outback H2.5l. It originally had good NGK Iridium Plugs; I decided to try Pulstar Iridiums based on positive reviews.
The Subaru now gets approximately 15% better fuel economy, some of which must be attributed to changing the plugs at 60,000 miles alone. I do believe that the Pulstar plugs are somewhat more efficient than the OEM NGKs.
I can say that the Outback never got better than 28 MPG on the highway with all seats full and driving 5 MPH over the limit; it will now get over 29 with all seats full, going 10 MPH over the speed limit.
The Pulstars are more expensive, but even a 5% increase in fuel economy pays for itself pretty quickly. I look at these plugs much like fully synthetic oils; they will increase mileage and performance, but not a whole lot.
