This site may earn a commission from merchant affiliate links, including eBay, Amazon, Skimlinks, and others.
Does anybody know what size IMPCO carburator/mixer is campadible with the 2F? I was thinking 425 but then I looked on IMPCO's website and they matched me up with one way smaller. I plan on building the motor for propane(high compression). Any ideas?
"The true act of volunteering is doing a job for free that you would not normally take for pay." Jes Harrington '23-'07
"Everyone has a plan until they get hit." Mike Tyson
'93 4Runner 4x4, 5 Speed, 1.5" ball joint spacers and downey rear springs.
rock scientist..
Staff member
s-Moderator
Moderator
425 is fine for a 2F
That is what I use.
BTW, buy new..
Course I'll see one that needs a rebuild for like $50
"Hallucinations are bad enough. But after awhile you learn to cope with things like seeing your dead grandmother crawling up your leg with a knife in her teeth. Most acid fanciers can handle this sort of thing. But nobody can handle that other trip-the possibility that any freak with $1.98 can walk into the Circus-Circus and suddenly appear in the sky over downtown Las Vegas twelve times the size of God, howling anything that comes into his head. No, this is not a good town for psychedelic drugs."
That is what I use.
BTW, buy new..
Do you trust rebuilt units? Is rebuilding much different from that of a gasser?
rock scientist..
Staff member
s-Moderator
Moderator
Impco carbs get richer as they age. A brand new one will get better mileage..
There are a total of three gaskets to replace. It is amazingly easy..
Are you running open or closed loop. I'm building this rig for trail use only, so I was thinking open loop was all I needed. Any more advice?
rock scientist..
Staff member
s-Moderator
Moderator
currently I am running open. Although I am switching to closed when I get around to putting the new carb on the truck..
What are you looking for?? Adjust your timing to 32* at full advance.
Close your plug gap..
Hot plugs are useless on a propane motor
Shave your head to get better compression to utilize the 105ish octane..
I saw where you are running about a 9:1 compression with a turbo. What do you think that effectively raises the compression too? I am thinking 11:1 will work well on a normally aspirated motor.
*Stupid question alert*
What's the diff between open and closed loop?
rock scientist..
Staff member
s-Moderator
Moderator
I am running a tired old stock cruiser motor with my turbo..
Compresison is more like 7.5:1 or so..
I have gotten 12 lbs of boost with it though.. Kick in the pants really..
11:1 on a cruiser motor even with propane will be a hard thing to keep from pinging..
keep it more like 9.5:1 or so..
To run closed loop you need an O2 sensor to modulate the mixture..
Autotronics makes a nice closed loop kit for the 425..
jesterb said:
Thanks alot, open loop for me!
rock scientist..
Staff member
s-Moderator
Moderator
the cool thing about closed loop propane is that if the electronics fail you revert back to open loop..
The carb is the same. It just gives you better mileage..
Hey Scott, have you heard anything else about a carb mounting plate?
rock scientist..
Staff member
s-Moderator
Moderator
get a holley butterfly plate (360 would work nicely) and a 2 to 4 barrell adapter.
Bolt it on..
Jesterb,
I've been trying to contact the propane guy through email to no avail. I will try and call him today though.
Bolt it on..
I've been told the 2 to 4 adapter was a bad idea. Do you know why that would be so?
rock scientist..
Staff member
s-Moderator
Moderator
Cannot think of one..
On a gas motor I can see a potential mixture issue. But with a propane carb you are already dealing with a vapor..
Who told you it was a bad idea???
You could always get a Offy 4 barrell 2F manifold ...
To be honest I cant remember. I've read so many posts on the issue that they are starting to run together. I might be confused with using a dual carb to single carb adapter.
I left a message with the propane guy, hopefully I'll hear from him soon.
Heard from Roy(propaneguy) and he told me to ship out the mounting plate from the carb. I'll keep you posted.
