- Location
- United States
Sold the rig and everything listed here, except the fj80 axle and dc shafts, still for sale
This is posted in the 45 section complete https://forum.ih8mud.com/fj45-class...b-crawler-project-thinking-about-selling.html , but I'm willing to sell parts from it. I will give priority to local pickup, but will ship on your dime from Santa Fe, 87505. Not sure if there is a local depot for truck freight, so that may not be an option for larger parts, try MudShip.
2003 vortec 4.3 complete with all accessories (except a/c compressor), wiring, mechanical fan, pcm from manual tranny ZR-2, exhaust manifolds. I don’t know the miles and never saw it run. I bought it from a salvage yard in 2005. The truck was rolled, so I assume the engine is fine and it should be low miles. I have the receipt ($1000) and VIN from the vehicle it came from. I occasionally squirt oil into the cylinders and turn it by hand. $500 obo
MC07 Marlin Crawler adapter with 1980 and 1981 t-cases. Inputs were upgraded to 23 spline on both. Front case totally rebuilt with Marlin kit. Never used. Might separate. $700 obo
Downey th-350 to 23 spline Toyota mini-truck t-case adapter. This is the short adapter (only 1 ½” deep) instead of the 6” adapter Advance sells. It includes a new mainshaft for the th-350 transmission. Never used. $300 obo
Toyota Tacoma e-locker rear axle from a 1999 TRD pickup. I don’t know the gear ratio, was going to change it anyway. Original perches were cut off, replacements tacked in place for my application. Also have a 1999 4runner e-locker axle, local club member has dibs if he wants it. $400 each obo
Narrowed Dana 44 front axle. From Chevy Blazer, so it has the thick tubes. I shortened the long side by 5 9/16”, left the short side alone. Overall width is ~62 ½” I think and 26 ¼” between spring perch centers. I turned the inner “C”s for several degrees of caster in my application. Includes stock 6-lug parts, flat-top knuckles, short side axle, both stub axles, AVM lockouts, etc. No new parts on it, I was going to build it. $100 obo
FJ80 front axle from a 1991. From a salvage yard, don’t know the miles or condition of the birfields, but it is complete. $200 obo
Centech wiring harness. Printed circuit fuseblock with brushed stainless cover. Automotive Fuse Panels From Centech Only install the circuits you need, you aren’t stuck with pre-terminated wires like Painful Wiring. Each wire printed with it’s destination. The rig was mostly wired years ago, so many of the wires are cut to length for this application—fusebox is under dash on driver side, wired front/rear lights, engine, don’t think I did gauges, wipers, or heater. Includes wiring to stock GM steering column/ignition/charging and new headlight switch. I paid $600, sell for $100
th350 transmissions. One rebuildable core from 4wd, one “K” case (stronger case originally from 4wd) with unknown internals. I don’t have the cast TC cover or braces for it. $50 for both.
DC Toyota driveshafts. I have to check what I have, but I know I have early mini-truck, maybe also FJ60. Probably all need rebuilt. $40 each.
