Prinsu Awning Mounts - quick mounting?
Houston
Are the Prinsu awning mounts fairly quick to mount/unmount an awning?
I have an ARB 2500 awning and am considering a Prinsu rack system. I am trying to understand if the Prinsu mounts support a quick mount/unmounting for awnings, or if they are more of a install and leave it on type mount.
I do not plan to leave my awning on 100% of the time. For the Prinsu mounts, I am assuming the mounts will stay attached to the awning and both the awning/mount combo will be mounted/unmounted onto the rack.
Not sure about the Prinsu product, but Ironman 4X4 offers some quick release mounting brackets that look interesting. I’ve ordered a set, along with the spare hooks which allow easy swapping of the awning from one side of the vehicle to the other.
the prinsu awning mounts take 4 screws on each mount. they stay with the awning. you just set the mounts on the side rail and slide the screws (captive in the crossbars) into cutouts in the mounts. then install washers/lock nuts on the screws.
i had to widen the cut outs where the screws slide in, and i keep washers and nyloc nuts on the screws or else the vibrate and rattle.
i can mount/dismount the awning in less than 10 min.
