SOLD PRICE DROP - AGAIN ($19,800) - SW Missouri - 2010 GX 460
Year
2010
  1. GX460
Mileage
171000
Color
White
Outside Link
https://www.facebook.com/marketplace/item/1155004899247551
Lexus GX 460 with a good start for overlanding, camping, etc.. Very reliable/sound vehicle.
Includes:
ARB Bumper
Badlands XRC 9500 lb winch
Old Man Emu (OME) lift
RSG Rock Sliders
Fuel Wheels
Cooper AT3 285/70r17 (33") tires with a lot of tread.
Excellent shape for a 2010.
The few issues (that don't effect reliability at all):- At least one TPMS is out so the low tire light is on.- The chrome door handles have cracks but can't even be felt when opening/closing.- A couple of small dings that you'd have to look for.
$22,800
$19,800
Lexus dealership maintenance records added a few posts down.
More pics on FB link:
FB Ad
Dealership maintenance records:
5/21/2024 (168202 miles)​
REPAIR NUMBER: 0186659
REPORTED BY: Reliable Lexus
SERVICE:
DESCRIPTION: PERFORM OIL AND OIL FILTER CHANGE USING 0W-20 GENUINE LEXUS OIL AND GENUINE LEXUS FILTER. PERFORM ~|~PERFORM OIL AND OIL FILTER CHANGE USING 0W-20 GENUINE LEXUS OIL AND GENUINE LEXUS FILTER. PERFORM COMPLIMENTARY VEHICLE INSPECTION INCLUDING TOPPING OFF FLUIDS AND ADJUSTING TIRE PRESSURE.
SERVICE: PERFORM ROTATION AND BALANCE OF TIRES
DESCRIPTION: ~|~PERFORM ROTATION AND BALANCE OF TIRES ~|~ ~|~168202 MAINTENANCE 100 PERFORMED A TIRE ROTATION AND BALANCE
SERVICE: PERFORM WORLD CLASS INSPECTION
DESCRIPTION: ~|~PERFORM WORLD CLASS INSPECTION ~|~
SERVICE: PERFORM POWER STEERING FLUID EXCHANGE.
DESCRIPTION: ~|~PERFORM POWER STEERING FLUID EXCHANGE. ~|~ ~|~168202 MAINTENANCE 100 PERFORMED A POWER STEERING FLUID EXCHANGE
11/7/2023 (162853 miles)​
REPAIR NUMBER: 0182467
SERVICE: REPLACED AND PROGRAMMED ONE NEW TPMS
DESCRIPTION: ~|~CUSTOMER STATES THE LOW TIRE LIGHT BLINKS ADVISE ~|~ ~|~162853 SENSOR #1 NOT READING 100 REPLACED AND PROGRAMMED NEW SENSOR IN SPARE TIRE
SERVICE:
DESCRIPTION: PERFORM OIL AND OIL FILTER CHANGE USING 0W-20 GENUINE LEXUS OIL AND GENUINE LEXUS FILTER. PERFORM ~|~PERFORM OIL AND OIL FILTER CHANGE USING 0W-20 GENUINE LEXUS OIL AND GENUINE LEXUS FILTER. PERFORM COMPLIMENTARY VEHICLE INSPECTION INCLUDING TOPPING OFF FLUIDS AND ADJUSTING TIRE PRESSURE. ~|~ ~|~162853 MAINT 50 OIL CHANGE COMPLETE
DESCRIPTION: ~|~PERFORM ROTATION AND BALANCE OF TIRES ~|~ ~|~162853 MAINT 100 ROTATE AND BALANCE COMPLETTE
6/15/2023 (157986 miles)​
REPAIR NUMBER: 0179159
SERVICE:
DESCRIPTION: PERFORM OIL AND OIL FILTER CHANGE USING 0W-20 GENUINE LEXUS OIL AND GENUINE LEXUS FILTER. PERFORM ~|~PERFORM OIL AND OIL FILTER CHANGE USING 0W-20 GENUINE LEXUS OIL AND GENUINE LEXUS FILTER. PERFORM COMPLIMENTARY VEHICLE INSPECTION INCLUDING TOPPING OFF FLUIDS AND ADJUSTING TIRE PRESSURE. ~|~ ~|~157986 PERFOMRED LOF SERVICE 50
DESCRIPTION: ~|~PERFORM ROTATION AND BALANCE OF TIRES ~|~ ~|~157986 PERFOMRED ROTATE AND BALANCE 100
SERVICE:
DESCRIPTION: PERFORMRECOMMENDED BRAKE FLUID EXCHANGE. LEXUS RECOMMENDS EXCHANGING BRAKE FLUID EVERY 3 YEARS O ~|~PERFORM RECOMMENDED BRAKE FLUID EXCHANGE. LEXUS RECOMMENDS EXCHANGING BRAKE FLUID EVERY 3 YEARS OR 30K MILES. ~|~ ~|~157986 PERFOMRED BRAKE FLUID EXCHANGE 100
SERVICE:
DESCRIPTION: PERFORM RECOMMENDED BRAKE FLUID EXCHANGE. LEXUS RECOMMENDS EXCHANGING BRAKE FLUID EVERY 3 YEARS O
10/4/2022 (152453 miles)​
REPAIR NUMBER: 0173620
SERVICE:
DESCRIPTION: PERFORMOIL AND OIL FILTER CHANGE USING 0W-20 GENUINE LEXUS OIL AND GENUINE LEXUS FILTER. PERFORM ~|~PERFORM OIL AND OIL FILTER CHANGE USING 0W-20 GENUINE LEXUS OIL AND GENUINE LEXUS FILTER. PERFORM COMPLIMENTARY VEHICLE INSPECTION INCLUDING TOPPING OFF FLUIDS AND ADJUSTING TIRE PRESSURE. ~|~ ~|~152453 PERFOMRED LOF SERVICE 50
SERVICE: DEFAULT
DESCRIPTION: ~|~MULTI-POINT VEHICLE INSPECTION ~|~
SERVICE: ENGINE
DESCRIPTION: ~|~NEED ESTAMENT FOR A NEW FUEL SENDING UNIT - HE RAN OUT AT 1/4 TANK ~|~ ~|~152453 SEE ESTAMENT
SERVICE:
DESCRIPTION: COMPLIMENTARYLEXUS LOANER VEHICLE PROVIDED BY RELIABLE LEXUS ($100 PER DAY VALUE, ELIGIBILITY REQ ~|~COMPLIMENTARY LEXUS LOANER VEHICLE PROVIDED BY RELIABLE LEXUS ($100 PER DAY VALUE, ELIGIBILITY REQUIREMENTS APPLY) ~|~
SERVICE: ENGINE
DESCRIPTION: ~|~REPLACE FUEL SENDING UNIT PER EST ~|~ ~|~152453 REPLACED FUEL SENDING UNIT PER CUST REQUEST 320
6/30/2019 (112962 miles)​
REPAIR NUMBER: 0158878
REPORTED BY:
SERVICE: COMPLETE AND OIL AND FILTER CHANGE
DESCRIPTION: ~|~ ~|~ ~|~
SERVICE: MULTI POINT INSPECTION, CHECK AND REFILL ALL FLUIDS AND CHECK AIR IN TIRES
7/19/2018 (101526 miles)​
REPAIR NUMBER: 0391438
REPORTED BY: Lexus of Tulsa
SERVICE: OTHERS
DESCRIPTION: ~|~C/S: CUSTOMER STATES CHECK ENGINE LIGHT 4 LO LIGHTS ARE ON. CHECK ADVISE. WARRANTY ENHANCEMENT PROGRAM ZLH CERTAIN 2010 - 2013 MODEL YEAR GX460 VEHICLES EXTENSION OF WARRANTY COVER AGE FOR AIR INJECTION PUMPS AND AIR SWITCHING VALVES ~|~CSP COVERAGE AVAILABLE FOR AIR INJECTION VALVES AND PUMPS P2445 SEC. AIR INJ. SYS. PUMP STUCK OFF ~|~REPLACED PUMP AND VALVE, FOR SEC. AIR INJ. SYS. RAN SELF CHECK ON SYSTEM. NO MALFUNCTIONS AT THIS TIME.
9/5/2017 (91673 miles)​
REPAIR NUMBER: 0369102
SERVICE: FRONT WHEEL ALIGNMENT
DESCRIPTION: ~|~ADVANCED IF NEEDED==PULLS LEFT ~|~LAST 8/9/16 ADJUSTED FOR PULLING RIGHT. RE-SET TIRE PRESSURE AT 35PSI. ~|~CHECK ALIGNMENT AND ADJUSTED TOE ONLY AT THIS TIME.
SERVICE: NON WARRANTABLE OPERATION CODE
DESCRIPTION: ~|~REPLACE ENGINE AIR FILTER ~|~FILTER DIRTY ~|~REPLACED ENGINE AIR FILTER
DESCRIPTION: ~|~REPLACE A/C CABIN AIR FILTER ~|~FILTER DIRTY ~|~REPLACED A/C CABIN AIR FILTER
SERVICE: REPLACE BRAKE FLUID
DESCRIPTION: ~|~PERFORM BRAKE FLUID REPLACEMENT ~|~REPLACE BRAKE FLUID ~|~DRAIN AND REFILL BRAKE FLUID
SERVICE: SPECIAL SERVICE CAMPAIGN
DESCRIPTION: ~|~C/S: GLG AIRBAG RECALL ~|~CAMPAIGN ~|~PERFORMED SAFETY RECALL GLG (INTERIM G2G) REMEDY NOTICE MULTIPLE MODELS AND MODEL YEARS FRONT PASSENGER AIRBAG INFLATOR IS 250, IS 350 AND IS-F AGGC7X 4.2 HRS/VEH ES 350 AGGC7Y 2.8 HRS/VEH
DESCRIPTION:
DESCRIPTION: ~|~MULTI-POINT VEHICLE INSPECTION ~|~COMPLIMENTARY INSPECTION ~|~PERFORMED FREE VEHICLE REPORT CARD INSPECTION
8/9/2016 (83877 miles)​
REPAIR NUMBER: 0338841
SERVICE: FRONT AXLE
DESCRIPTION: ~|~C/S THE DRIVER SIDE FRONT WHEEL STRUCK A MEDIAN ON THE HIGHWAY AND THE CAR SHIMMIES AT LOWER SPEEDS==CK OVER AND ADVISE ~|~ ~|~2 WHEELS DAMAGED. REPLACED ALL 4 CHROME WHEELS. TWO TIRES COULD POSSIBLY HAVE SIDEWALL DAMAGE.
DESCRIPTION: ~|~ALIGN==PULLS RIGHT ~|~ ~|~PERFORMED ALIGNMENT. TEST DROVE TO VERIFY VEHICLE DRIVES STRAIGHT.
SERVICE: POWER STEERING FLUSH
DESCRIPTION: ~|~PERFORM POWER STEERING FLUSH SERVICE ~|~POWER STEERING FLUSH ~|~PERFORMED POWER STEERING FLUSH SERVICE
DESCRIPTION: ~|~PERFORM TRANSMISSION FLUSH SERVICE ~|~FLUSH TRANSMISSION ~|~COMPLETED TRANSMISSION FLUSH SERVICE
SERVICE: OTHERS
DESCRIPTION: ~|~ ~|~ ~|~PERFORMED FRONT BRAKE JOB
SERVICE: OTHERS
DESCRIPTION: ~|~ ~|~ ~|~PERFORMED REAR BRAKE JOB
SERVICE: CK FLOOR MAT INST.
DESCRIPTION: ~|~CHECK INSTALLATION OF DRIVERS SIDE FRONT FLOORMAT ~|~INSPECTED DRIVERS SIDE FRONT FLOORMAT ~|~SEE SERVICE CONSULTANT WITH ANY QUESTIONS ON PROPER FLOORMAT INSTALLATION.
DESCRIPTION: ~|~PERFORM FREE VEHICLE REPORT CARD INSPECTION ~|~COMPLIMENTARY INSPECTION ~|~PERFORMED FREE VEHICLE REPORT CARD INSPECTION
4/16/2015 (75064 miles)​
REPAIR NUMBER: 0301845
SERVICE: 75K MILE SVC
DESCRIPTION: ~|~CUSTOMER REQUESTS A 75K MILE SERVICE ~|~CUSTOMER REQUESTS A 75K MILE SERVICE ~|~PERFORMED A 75K MILE SERVICE PER CUSTOMER'S REQUEST
SERVICE: RADIATOR-FAN
DESCRIPTION: ~|~THERE IS A SQUEAKING NOISE THAT SOUNDS LIKE A BELT CK AND ADVISE ~|~FOUND WATER PUMP LEAKING AND DRIVE BELT WORN ~|~REPALCE DRIVE BELT AND WATER PUMP
DESCRIPTION: ~|~FREE 30 POINT INSPECTION ~|~FREE 30 POINT INSPECTION ~|~FREE 30 POINT INSPECTION
SERVICE: BRAKE INSPECTION
DESCRIPTION: ~|~BRAKE(S) REQUIRES FUTURE ATTENTION ~|~ ~|~REAR BRAKES 4MM
6/17/2014 (70280 miles)​
REPAIR NUMBER: 0278223
SERVICE: 70K MILE SVC
DESCRIPTION: ~|~CUSTOMER REQUESTS A 70K MILE SERVICE ~|~CUSTOMER REQUESTS A 70K MILE SERVICE ~|~PERFORMED A 70K MILE SERVICE PER CUSTOMER'S REQUEST
DESCRIPTION: ~|~30 POINT ~|~.
SERVICE: WASH AND VACUUM
DESCRIPTION: ~|~WASH AND VACUUM ~|~. ~|~WASH AND VACUUM
SERVICE: ROTATE TIRES (TPP)
DESCRIPTION: ~|~ROTATE TIRES - TIRE PURCHASE PACKAGE NO CHARGE ~|~ROTATE TIRES - TIRE PURCHASE PACKAGE ~|~ROTATE TIRES - TIRE PURCHASE PACKAGE NO CHARGE
4/29/2014 (68262 miles)​
REPAIR NUMBER: 0274650
SERVICE: RADIO TUNER ASSEMBLY
DESCRIPTION: ~|~C/S: C/S THAT RIGHT TUNING NOB ON HIS RADIO HAS BROKEN OFF. ~|~ ~|~REPLACED BROKEN RADIO KNOB
SERVICE: WHEEL ALIGNMENT
DESCRIPTION: ~|~THE CAR PULLS RIGHT ~|~ ~|~PERFORMED ALIGNMENT .ADJUSTED RIGHT FRONT CASTER AND FRONT TOE .STILL HAD SLIGHT PULL .AFTER SWAPPING FRONT TIRES NO LONGER PULLS .ADVISE CUSTOMER ON TIRE PULL .
SERVICE: MOUNT & BAL. TIRES
DESCRIPTION: ~|~MOUNT AND BALANCE TIRE(S) INSTALL FOUR MICHELIN SKU#15845 ~|~REQUIRES D.O.T. NUMBERS ~|~MOUNT AND BALANCE TIRE(S) AND REPLACE FIT KITS WHERE APPLICABLE
DESCRIPTION: ~|~30 PT INSPECTION ~|~ ~|~ADVISE CUSTOMER ON TRANS FLUSH
DESCRIPTION: ~|~HAS SCREW IN RIGHT FRONT TIRE ~|~ ~|~PERFORMED TIRE REPAIR ON RIGHT REAR TIRE
11/25/2013 (65239 miles)​
REPAIR NUMBER: 0263210
SERVICE: 60K MILE SVC
DESCRIPTION: ~|~CUSTOMER REQUESTS A 60K MILE SERVICE===ONLY DO FILTERS IF NEEDED THEY WERE REPLACED AT 50K ~|~CUSTOMER REQUESTS A 60K MILE SERVICE ~|~PERFORMED A 60K MILE SERVICE PER CUSTOMER'S REQUEST
DESCRIPTION: ~|~30 PT ~|~
1/16/2013 (55422 miles)​
REPAIR NUMBER: 0239681
SERVICE: 55K MILE SVC
DESCRIPTION: ~|~CUSTOMER REQUESTS A 55K MILE SERVICE ~|~CUSTOMER REQUESTS A 55K MILE SERVICE ~|~PERFORMED A 55K MILE SERVICE PER CUSTOMER'S REQUEST
DESCRIPTION: ~|~PLEASE UPDATE NAVIGATION SYSTEM ~|~ ~|~UPDATED NAV SYSTEM
DESCRIPTION: ~|~30 POINT INSPECTION ~|~BATTERY FAILED LOAD TEST ~|~CUSTOMER DECLINED BATTERY
11/9/2012 (51519 miles)​
REPAIR NUMBER: 0234808
SERVICE: MISC
DESCRIPTION: ~|~C/S REMOTE START IS INOP. INTERMITTANTLY. C/S COULD BE A RANGE ISSUE ALSO. CHECK AND ADVISE. ~|~ ~|~STARTED VEHICLE SEVERAL TIMES. COULD NOT DUPLICATE CUSTOMER CONCERN AT THIS TIME. VEHICLE STARTED EVERY TIME FROM VARYING DISTANCES. BE ADVISED THAT TO START VEHICLE, REMOTE LOCK BUTTON HAS TO BE PRESSED 3 TIMES AND HELD ON THE 3RD TIME. AS LONG AS THE VE
DESCRIPTION: ~|~ ~|~ ~|~PERFORMED INSPECTION
9/4/2012 (50202 miles)​
REPAIR NUMBER: 0229682
SERVICE: 50K MILE SVC
DESCRIPTION: ~|~CUSTOMER REQUESTS A 50K MILE SERVICE ~|~CUSTOMER REQUESTS A 50K MILE SERVICE ~|~PERFORMED A 50K MILE SERVICE PER CUSTOMER'S REQUEST
DESCRIPTION: ~|~ ~|~PERFORMED INSPECTION
DESCRIPTION: ~|~ ~|~ ~|~INSTALLED NEW ENGINE AIR FILTER
SERVICE: REPL. CABIN FILTER
DESCRIPTION: ~|~ ~|~ ~|~INSTALLED NEW CABIN AIR FILTER
DESCRIPTION: ~|~ ~|~ ~|~CUSTOMER DENIED SERVICE - WILL COMPLETE AT NEXT VISIT
10/27/2011 (26804 miles)​
REPAIR NUMBER: 0204987
SERVICE: 25K MILE SVC
DESCRIPTION: ~|~CUSTOMER REQUESTS A 25K MILE SERVICE ~|~CUSTOMER REQUESTS A 25K MILE SERVICE ~|~PERFORMED A 25K MILE SERVICE PER CUSTOMER'S REQUEST FRONT AND REAR BRAKES HAVE 7MM REMAINING FRONT TIRES HAVE 6/32 TREAD REMAINIG REAR TIRES HAVE 4/32 TREAD REMAINING NEXT SERVICE IS DUE AT 30,000 MILES
7/6/2011 (20756 miles)​
REPAIR NUMBER: 0195744
SERVICE: 20K MILE SVC
DESCRIPTION: ~|~CUSTOMER REQUESTS A 20K MILE SERVICE ~|~CUSTOMER REQUESTS A 20K MILE SERVICE FRONT AND REAR BRAKES 8MM REMAINING FRONT AND REAR TIRES 6/32 REMAINING ~|~PERFORMED A 20K MILE SERVICE PER CUSTOMER'S REQUEST
DESCRIPTION:
5/5/2011 (15219 miles)​
REPAIR NUMBER: 0190653
SERVICE: 15K MILE SVC
DESCRIPTION: ~|~CUSTOMER REQUESTS A 15K MILE SERVICE ~|~CUSTOMER REQUESTS A 15K MILE SERVICE ~|~PERFORMED A 15K MILE SERVICE PER CUSTOMER'S REQUEST
DESCRIPTION: ~|~ ~|~.
3/22/2011 (12520 miles)​
REPAIR NUMBER: 0187026
SERVICE: TRAILER HITCH
DESCRIPTION: ~|~INSTALL TRAILER HITCH ~|~CUSTOMER REQUESTED TRAILER HITCH ~|~PERFORMED
5/12/2010 (362 miles)​
REPAIR NUMBER: 0422547
REPORTED BY: Sterling McCall Lexus
SERVICE: SUBLET
DESCRIPTION: ~|~REPAIR AND DYE REAR PLASTIC TRIM PANELS
5/13/2010 (361 miles)​
REPAIR NUMBER: 0422329
SERVICE: DONE
DESCRIPTION: ~|~SWAP PANELS WITH ST#A5006082 CHARGE TO ST#A5007260
5/12/2010 (357 miles)​
REPAIR NUMBER: 0422288
SERVICE: INSTALL WINDOW TINT ON TWO WINDOWS
DESCRIPTION: ~|~INSTALL WINDOW TINT ON TWO WINDOWS
5/5/2010 (16 miles)​
REPAIR NUMBER: 0421344
SERVICE: =INSTALL CHROME OR CUSTOM WHEELS
DESCRIPTION: ~|~CUSTOMER RIM CHROME OEM ~|~ ~|~16 INSTALLED OEM RIMS
SERVICE: REAR HEAD REST DVD
DESCRIPTION: ~|~INVISION HEADREST DVD ~|~ ~|~16 INSTALLED DVD HEAD RESTS
SERVICE: DONE
DESCRIPTION: ~|~EXACT MATS ~|~ ~|~16 FLOOR MATS
4/30/2010 (15 miles)​
REPAIR NUMBER: 0420818
SERVICE: ALB REPROGRAM VSC ECU GX460
DESCRIPTION: ~|~2010 GX 460 COMPUTER REFLASH CAMPAIGN ~|~F
4/13/2010 (12 miles)​
REPAIR NUMBER: 0418229
SERVICE: WASH VEHICLE
DESCRIPTION: ~|~WASH VEHICLE
3/9/2010 (6 miles)​
REPAIR NUMBER: 0412651
SERVICE: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES
DESCRIPTION: ~|~PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES ~|~PDI
SERVICE: =NEW CAR STATE 2 YEAR
DESCRIPTION: ~|~=NEW CAR STATE 2 YEAR
SERVICE: INSTALL NITROGEN IN ALL TIRES
DESCRIPTION: ~|~INSTALL NITROGEN IN ALL TIRES
SERVICE: FRONT LINE WASH PDI
DESCRIPTION: ~|~FRONT LINE WASH PDI
