Powersteering
Alright people.....I told those f#%$^& to not do the work on my vehicle. I saved myself alot of money in my book. This is my first real vehicle that requires real maintainence. I know it sounds retarded but I need this "hassle" right now plus I love my LC. Anyhow, I swapped out the belts. Took a little bit but I did. However, when I turn the wheel all the way right or left i'm hearing a grind. I'm thinking I tightened the belt too tight. Also, the engine drops its idle down. I'm assuming I need to loosen the belts. By the way guys....I appreciate all of your help with all matters pertaining to my new found love or sickness which ever it maybe.
grind can be common but you want to check your PS fluid level just in case.
Idle down at full lock is fairly common as the pump is under alot more stress at full lock.
what you need is a digital camera so you can take some pics of your engine/PS pump/ and steering box and post them up here for us to see.
This will go a LONG way to letting us help you out ;)
usually you pull the return line (low pressure... the one with hose clamps) put it in something to catch the fluid and turn the wheel pumping fluid out.
I think you want to avoid running the pump dry though (bad for the pump)
That's just an overview though. Others will hopefully chime in with better info.
Again, pics would let us give you more detailed info.
I would recommend that you remove the low pressure line at the gear box and put a temporary hose on. Then put both lines (from pump and gear box) into a bucket (2 quarts capacity). Raise the front axle off the ground (both wheels) and run the steering wheel lock to lock (engine off) until no fluid comes out of the two low pressure lines. Remove the line from the gear box and reconnect the line from the pump to the gear box. When finished, follow the instructions for bleeding the air out of a power steering system at the link below. AGR makes the best Saginaw P-series pump you can buy and they are very particular about the system being set up correctly.
http://www.agrperformance.com/APRIL_2003__INSTALLATION_IN.PDF
Does this truck have a V8 in it?
How many belts? or is it a single flat wide belt that covers all of the pulleys?
Carb or fuel injected?
take off the one that goes to the powersteering, and buy one the some size and replace
I already changed it out yesterday. However, I am getting a grinding when I lock left and right. I looked in the pump and it needs fluid as well. Maybe my belts are too tight.
squealing is usually a loose (or maybe worn) belt
grinding (sounds like a whirring) is your pump.
usually if it is only making the noise when under pressure at full lock it's ok. that's fairly normal. It could mean your pump is wearing out though. Make sure the fluids topped off.
if it's constantly making the noise while driving or turning in a parking lot it could mean it's on it's way out. It could also be low on fluid and need air bled out. (simply jacking the front up and turn lock to lock many times with the engine running. Keep a close eye on fluid level when doing it)
Keep an eye out for leaks around the pump (and elsewhere.... saginaw steering boxes tend to leak. is your box up front or back behind the DS tire?).
don't overfill it or it will spew out the cap when under load ;p
Actually my box is on the side of the DS tire next to the engine. It doesn't really reside in the front nor the back. I guess it would be toward the back of the tire. Anyway, if I need a new pump then how would I shop for one? Would i get one just for a CHevy 305 or what?
OK, this tells me you probably have a Toyota Mini truck (pickup) PS system. Pretty common (what I have) just check that nothings leaking from around there. Shouldn't be, but could be....
Don't freak out yet, hopefully you don't need one. One step at a time. Figure out WHEN it's making the noise, and topp the fluid off. If you do end up needing one, someone here can tell you what make/model truck to tell the parts guy. Of course we would want a picture to make sure..... otherwise we're guessing.
