Power Steering Pump Replacement
Vermont
What's the best site/store to source a Power Steering Pump from? I have a 2004 4Runner Sport Edition.
Vehicle has been steering a bit hard for the lat week. Started with a noise from what sounded like the pump but that went away after a couple of days. Hard steering is still there.
Anything else I should replace while I'm at it? Did the drive belt, tensioner, and AC relay about 10K miles ago.
Have you tried flushing the reservoir screen? Pita to do, but may be causing the issues… and cheaper than a new pump.
Any walk through on how to do that?
You could probably find a video online.
Hopefully the steering rack isn't crapping out on you. For other things to replace with a steering pump, the high pressure line is a common thing to do.
I've heard to also check the Steering Shaft that runs to the steering wheel...
Visually inspect for wear or slop in u joint if so equipped. My brother in law with H2 had a rusty steering joint that needed replacement. Usually there’s no way to lube these pieces.
