Here's the skinny:
Started hearing a "ca-clunk. . . ca-clunk. . . . ca-clunk" as i was idoling at approx. 5-15 mph in a parkinglot, or up against a curb with the windows down and the radio off. Testing revealed that no matter which way i turned (left or right) it would make this noise at all times except when the drivetrain is under load from acceleration. During coasting or braking the "ca-clunk. . ca-clunk ect.." was present. The best i can describe the sound is a matalic clunk and not a clicking like a worn birf. Almost like a driveshaft.
Put the truck up on 4 jackstands today and put it in gear so i could lie under her and listen. Best i could tell is it was coming from inside the RF knuckle. I pretty much ruled out it coming from that side of the diff. and it definately wasn't the dirveshaft. So i dug in.
As i popped the outter snap ring off, i noticed a lot of inward and outward play. More than i think was standard. As i pulled the axle hub out, the inner face of the outter bearing had some rusty grease on it. The knuckle spindle also had a little bit of this rusty grease on the inside of it. As i dug in deeper and pulled the birf out, i noticed a slight amount of diff oil in the cavity, but not too bad. I think the seal was holding up pretty well and there was no rusty grease in the cavity.
Close examination of the birf showed no scaring on the outside which would lead me to think it was not flopping around and hitting the cavity. There was about 1/4" - 1/2" play with the axle that inters the bell, pulling in and out. But the articulation movement felt good.
Examination of the knuckle spindle showed a little bit of a groove where the inner bearing rides on it. Also, and i'm not sure if this is supposed to be like it, but the inner bearing was loose to the hand. I just figured it would tighten itself as i put the hub back on and set the preload. Anyways, i extracted the bearing and repacked it, put it back in, repacked the birf and buttoned everything back up to spec.
Took it for a drive and it's still doing the same thing. What the heck is it? Is it in the diff? Is the inward and outward play of the inner axle causing some havock in the birf joint? I don't know.
