Position of Aluminium Hawse Fairlead?
Kelowna, BC
I am replacing my steel wire rope on my BJ74 PTO winch with synthetic rope. I need to replace the old steel roller fairlead with an aluminum hawse fairlead and have a question with respect to its best position.
The PTO winch steel roller fairlead, which has a 2 1/2" slot between the top and bottom roller is centered on the drum. Aluminum hawse fairleads typically have a slot of less than 1". Positioning the new fairlead on the center of the drum would result more downward deflection of the cable through the narrower slot, even on a straight pull, since the wire rope comes off the top of the coil on the PTO winch. (I believe most others come off the bottom).
So I am considering moving the new aluminum fairlead up from center on the drum - so my question is by how much?
This is part of my PTO 'front porch' renovation project this spring :hillbilly: which involves removing my mangled front bumper and the front 3" channel the steel roller fairlead sits in...
Its a catch 22 situation, as you spool rope off (on a straight pull) it will hit the bottom of the hawse.
I would just aim for a mid point between fully spooled rope on the drum and no rope.
At some point in your winching its going to be rubbing on the hawse....
you can also find the hawse with the slot offset for exactly that reason....check out Viking, MasterPull and a few other synthetic rope vendors and you should find what you are lookin for.
Winchline Fairleads
Winch Rope, Synthetic Winch Rope, ATV Winch Ropes
