SOLD Portland, ME: 2008 GX470 - Clean southern truck with extensive service history
Year
2008
  1. GX470
Mileage
223000
Color
rgb(254, 255, 239)
2008 GX470 in Blizzard Pearl with Tan/Walnut Interior
VIN JTJBT20X280164058
223,XXX miles
Options:
  • Navigation (later, improved version) & Mark Levinson Audio
  • Non-KDSS
  • 3rd row seats (with rear A/C)
  • Tow Package (factory 2" receiver and wiring)
  • Rear spoiler & Fancy exhaust tip
Service History (all done at Lexus dealerships prior to ~200k):
  • 5,469 - "warranty service"
  • 10,941 - oil & filter
  • 16,696 - oil & filter, alignment
  • 22,985 - oil & filter
  • 28,725 - oil & filter, alignment
  • 34,148 - oil & filter
  • 37,353 - new mirror control ecu
  • 40,856 - oil & filter
  • 46,896 - oil & filter
  • 53,233 - oil & filter
  • 57,560 - new gas cap
  • 57,881 - oil & filter
  • 63,438 - oil & filter, wiper inserts
  • 68,855 - oil & filter
  • 75,452 - oil & filter, new brake fluid, front & rear brake pads, resurface rotors, left & right axle boots, cabin filter, air filter, alignment, lube driveshaft
  • 80,495 - oil & filter, new battery
  • 86,483 - oil & filter
  • 92,641 - oil & filter, timing belt, water pump, new brake fluid, air filter, cabin filter, front diff fluid, rear diff fluid, transfer case fluid, lube driveshafts
  • 98,424 - oil & filter
  • 104,687 - oil & filter, new coolant, alignment
  • 109,274 - oil & filter
  • 115,161 - oil & filter
  • 121,584 - oil & filter, lube driveshafts, spark plugs, air filter, wiper inserts, alignment
  • 127,053 - oil & filter
  • 128,018 - new fuel cap
  • 132,692 - oil & filter
  • 137,580 - oil & filter, lube driveshafts, alignment
  • 143,203 - oil & filter
  • 144,748 - new left front wheel bearing & hub
  • 149,497 - oil & filter
  • 155,482 - oil & filter, new front brake pads, resurface rotors, new brake fluid, new coolant, air filter, cabin filter, lube driveshafts,
  • 159,644 - alignment
  • 162,429 - oil & filter, alignment, rear brake pads & resurface rotors, new right front axle, new left front axle
  • 167,450 - oil & filter
  • 200,318 - oil & filter, timing belt, tensioners, pulleys, water pump, serpentine belt (have receipt)
  • 222,700 - air filter (Denso), cabin filter (Denso), passenger front wheel bearing & hub (Beck/Arnley)
  • 222,761 - spark plugs (Denso), passenger rear wheel bearing & axle seal (Beck/Arnley)
  • 223,252 - new battery (Deka AGM), oil change (OEM Toyota filter & Mobil 1 High Mileage 5W-30)
Some Notes:
  • I believe this truck spent it's whole life in North Carolina until I purchased it and had it shipped to Maine. It has not seen any road salt since arriving here.
  • Interior shows some wear typical for the mileage.
  • Completely stock and unmolested except for: new Depo headlights just installed (will include the OEM headlights with sale) & secondary air injection bypass.
  • Windshield needs to be replaced but this will be done before the sale.
  • 3rd row seats are not pictured but they are included.
  • Clean AutoCheck report and clean title in hand.
  • Maine State Inspection good through 01/2021
I purchased this truck ~7 months ago (after a long search for a clean one) for an off-road "build".
Due to an unfortunate change in circumstances I won't even be able to start this project.
$9,900
