I'm checking the drive line of my 89 BJ74 with a LSD for vibrations. There is a bit of play in the rear pinion flange up and down when wiggling it. So I'm thinking the pinion nut is loose. I'm also going to replace the U-joints as there seems to be the onset of wear in the races.
What is the recommeded torque for the rear pinion nut? I've read somewhere it's between 181 and 325 ft *lb, which seems a lot. Do I have the numbers right?
Are the pinion nut and u-joints the same for BJ74 as for a BJ70?
Thanks!
Matthias
Thanks!
Matthias
