Phantom Misfires
Ridgefield CT
Looking for some help with phantom misfires... i have run out of ideas.
First some background - in early 2024 i took my 2002 LC w/375k mi on 2 long roadtrips 1) NY to FL, 2) NY to Montreal.
A couple months after these roadtrips, the truck developed a flashing CEL. Sometimes it would go away on its own, other times it would throw a Random Misfire code, accompanied by misfire codes for every cylinder. Occasionally it would throw the Random Misfire code and only Cylinders 5 & 8 would throw misfire codes. The catch is, there is no misfire that i can feel... truck drives normally. I drove it for a while hoping i would feel a misfire and replace a coilpack on that cylinder.
A short while later, the fuel pump went out on me. I replaced the fuel pump thinking that was also the reason for the codes. But, that didnt solve it. Since then i have replaced the following:
- all coil packs
- all spark plugs
- all injectors
- fuel filter
- gas cap
- several rounds of fuel system cleaner
- tested and cleaned MAF
- smoke tested EVAP and vacuum lines (replaced a couple lines and the solenoid that bolts to the intake manifold
- intake manifold gaskets
* The timing belt was done 2 years ago, less than 50k miles since
The intake manifold gaskets were the most recent. I am noticing that post, i am no longer getting just the cylinder 5&8 misfires, so i think that is resolved. But, i am still getting random misfire codes accompanied by all cylinder misfire codes.
The codes come up intermittently. I've narrowed it down to mostly cruising in 4th gear between 1-1.5k rpms. This is when i occasionally get a flashing CEL. Sometimes i can accelerate out of the flashing CEL by getting rpms up to 2k+. But, sometimes i get the codes at startup. And this is all intermittent. I cannot cause the codes to happen consistently
i have a replacement throttle body gasket on order but only for completeness on my intake manifold gasket replacement job.
Looking for suggestions on how to diagnose and next steps..... TIA
