Parts needed to complete my junk
Hiding
Guys, Thought I would start here and try to keep the $$ "local"
I need the following stuff:
Driver and Passenger Seatbelts. I have the female ends still on the seats I got from Nick, I just need the actual belts. Either lap or 3 point shoulders will work.
Speedo Cable. The type that has screws on both ends and will bypass the speed sensor. Its for a 70 FJ 40 Cluster.
Two new wiper arms. Top mount Motor. The ones I have are stripped out where they plug into the frame and mesh with the ribs on the frame piece. I have new blades Just really need the piece that goes over the posts on the windsheild frame. Also need the nuts for them too.
Heater Ducts. The two round ones that go the defrost from the front heater, and the square box that runs between the plastic housing off of the blower motor and the actuall front heater.
Passenger rearmost brake wheel cylinder. on the rear axle.
Driver side Side vew Mirror and a rear view mirror.
2f Fuel pump.
Let me know what you got before I go "public", I have sourced most of this stuff through CCOT and others, I just wanted to give you guys some money first.
Thanks Warren.
2f Fuel pump.
Thanks Warren.
What were the heater parts you gave me? You can have them back if it helps.
Those were extras. I have read some posts on getting the ducts from a hardware or something. But the square piece might be tricky.
http://www.sor.com/sor/cat186.tam?xax=23545&page.ctx=cat186.tam
Its part number 5 square heater Duct. I could probably fit a cardboard box over it and some duct tape, but that would ruin the effect of what I am going for:)
Spector has them for 28 bucks, just seeing if someone else does a bit cheaper.
Kewl.... :beer:
Warren,
I got one of those. It's yours for $15 shipped. Just shot a picture of what/where it needs to fit to make sure what I have is what you need. Trying to figure out how a cereal box and duct tape is "not the effect you were going for" though. :grinpimp:
Might also have the defrost hoses or a workaround but I need to see a shot of your heater to make sure I have the right parts.
Nick
I'll Get some pics tonight. Promise....
I am going for the Ghettofabulous/ dont laugh your daughter might be inside effect.
Sorry, Work got in the way.
heres a pick of the heater squares where the part missing is needed.
Side Bar.
The old Belly Dancer danced her last dance this summer....
So the new Tiny Dancer has taken her place.
I drained the gas from her into the cruiser tank, and replaced the PBR shifter on the Cruiser Transfer case in true red neck honor.
Warren,
What is the distance between the two openings? Pretty sure I have that piece though. Also need you to move th camera down a little so I can see the holes where the defroster hoses go on the heater box...
Nick
Side Bar.
Is that your new mower? That would be like going from a Cruza to a HEEP:flipoff2:
I like the paint job, true weekend warrior fashion too..
good luck finding one
The piece you need that goes between the heater and the duct is actually a rubber sleeve. If you saw one laying on the floor you would swear it was a section cut out of an old truck inner tube. You will not find one-they are all dry rotted and thrown out. I almost threw mine away thinking it was a piece of truck inner tube. The only difference is that there is a bend molded into the piece making it transition up and onto the heater box. At least that is how mine works. I will get a picture of it tonight and post it tomorrow.
here is what it looks like
pics of sleeve
I have most of the parts your looking for send me an email and I will try to get most of your parts out of boxes I have. I've owned about 35 cruiser so there always a few parts around. dave at rockntag@msn.com
