- Location
- United States
1993 FZJ80, locked, 208k miles. Below is the partial parts list, if you don't see the items that you want, please ask. Click here to contact me, and make sure your email in your profile is current.
Will ship from 85260.
Diff Lock Switch 84725-60020 $30.00
Differential lock ECU 89533-60030 $200.00
Front locker harness 82164-60012 $40.00
Rear locker harness 82165-60080 $85.00
Floor harness number 3, from rear right quarter panel to left quarter panel 82163-60051 $150.00
Main floor harness, from driver kick panel to rear left quarter panel 82161-60042 $300.00
All of the above -- $700
Distributor $50.00
Fuel injector resistor pack $15.00
ABS pump $25.00
Brake booster $25.00
Brake master $25.00
Cruise control assembly $35.00
Air cleaner housing $15.00
Heater control valve $10.00
Power steering high pressure hose $20.00
Front seats $50.00
Transmission control relay $50.00
ABS ECU $50.00
AC control panel $50.00
Power antenna switch $10.00
Rear heater switch $10.00
Power mirror switch $10.00
Headlight/turn signal switch $5.00
Front right window switch $10.00
Rear left window switch $10.00
Rear right window switch $10.00
Front right power lock actuator $10.00
Steering column $10.00
Transfer case shifter knob, leather in perfect shape $15.00
Rear view mirror $5.00
AC Vent $8.00
Glove compartment $15.00
Driver foot rest $5.00
Rear heater $20.00
Front wiper motor $10.00
Fuel tank $15.00
Rear left door panel $15.00
Rear right door panel $15.00
The following items are not available.
Distributor $50.00
ABS pump $25.00
Brake master $25.00
Front seats $50.00
ABS ECU $50.00
AC Vent $8.00
Rear heater $20.00
Fuel tank $15.00
- Engine
- Transmission & transfer case
- Front and rear axles
- Visors
- Jack and Tools kit
- Headlights
- Door mirrors
- Map light
- Seat belts
- Front signal lights
- Parking/marker lights
- Wheels, center caps and lug nuts
- Radio
- Exhaust and exhaust heat shield
- Center console
- Carpets
- Power steering reservoir
- Front left & right door panels
- Fusible links and wire to alternator
- Negative battery cable
- Dash trims
- Emergency brake handle & boot
- Third row seats brackets on the wheel wells
- Cargo area right panel
- Tailgate
- Rear left door lock actuator
- Driver door lock actuator
- Rear right power lock actuator
- Hazard switch
- Fan & fan clutch
- Front skid plate (stone tray)
- Power steering box
- Steering wheel
- Transmission cooler
- Rear drive shaft
- Grille
- Fan shroud
- Taillights
- AFM
- Fuel pump
- Front bump stops (in coil)
- Power antenna motor assembly
- AC compressor with clutch
- AC hose high pressure hoses
- AC amplifier
- AC evaporator
- Blower fan assembly
- Coil & ignitor
- Throttle body
- Charcoal canister
- ECT switch
- Front left door master switch
- Starter
- Rear defroster switch
- Dimmer switch
- ECU for engine
- Interior lights relay
- Rear wiper motor
- Steering damper bracket
- 2nd & 3rd row seats
