SOLD Original wheel cylinder cores.
Chico California
My 72 iron pig has a mis mash of all sorts of wheel cylinders and I'd like to go ahead and build 4 original Toyota cylinders.
My parts truck had them but I broke one rh front tearing it down.
I bought 2 from specter but they're new and have a Mitsubishi logo cast into them instead of TEQ.
I really need a right front, but I'd buy a box full if you've got them.
Would potentially trade parts if theres something you need I've got a -72 parts pig in the back 40.
Thanks and have a great day.
I’ check my 73 parts stash tomorrow. Pretty sure I have them
Sorry didn’t get out to check today. Will make a point to get out there tomorrow.
i have a MATCHING NOS set in all original parts boxes by OEM parts maker TOKICO ...
I have actually acquired enough cores to build a propper set for each of my pigs and I really don't mind the work. Plus I've got several good cores sitting in a box to rebuild for future needs. Nos, sounds nice, what do you get for a set?
(I'm a real bonafide hoarder I guess)
i just took fresh pics now
ill post here right now
if your interested i will give you a deal you can't refuse , i can tell you will be good home for them and your NOT a parts flipper
I also have a set of NOS OEM toyota parking brake drum shoes
In original parts box too
Do yours attach with banjos or flares? It looks like they have copper banjo bolt washers included which is great except mine have flared hydraulic fittings which I think are correct (3 or 4 parts donors all came flare equipped)
What's the relevant number?
I should honestly be saving for tires at this point, but like I said I'm a hoarder...
make me a offer i can't refuse and ALL the FJ55 brake parts are yours
i am easy going and not married to these ,
going to a use full home is my goal here ...
My brain says yes, but my bank account balance says "you better not"
Thanks for the kind offer but I think I have got enough here, and in the mail to complete both trucks.
I'll check my bank balance and get back to you within 24 hours.
i see you mentioned you have all miss matched wheel cylinders ?
i took the time of making sure they are
indeed a MATCHED / MATCHING set to one another , :)
also , if anyone has there doubt TOKICO was not one of the 2 OEM Parts makers that supplied TOYOTA with wheel cylinders and shock absorbers for the FJ55 FJ40 FJ60 Land Cruiser in addition to ASCO/ AISIN
I started with a mis matched bunch of crapola, I've received one set of cylinders from a member and I'm making a deal for another set of backing plates complete, which will have me nearly swimming in wheel cylinder cores.
Those are gorgeous and someone will certainly buy them.
that someone is you , and just don't know it yet ...... :cool:
s-l1600-11-jpg.3226767
