Ordered Kings for my 2017 200
Villa park ca
questions for people that have them or experience:
Im going use them to level the 200 (1" in the front) and for the great ride.
Seeing that im not cranking them up, do i really need UCA's?,, i was under the impression that they would be needed for 2'or more? I understand that i have to open the KDSS valve to allow it to compensate even for a inch
Im going to retain stock rear springs too, any thought for or against that?
I appreciate the input here, anything i should know more ?
For a 1" lift, you do not need new UCAs, those are more for 2.5" + lifts
I show it as KNG25001266 (front) and KNG25001267 (rear) . A buddy has access to buy them at jobber pricing for me-and im going to have the shop that built my rubicon install them
How much are they if I may ask? I had a hard time trying to figure out how much they ran? I went with Icons but almost switched to Kings. I am happy I kept the Icons because of the digressive shocks. Kings were my second choice but I can see why people prefer them.
Nice! Remote resis with adjusters?
I didn't get the adjustable, but did get resi's, but they are being valved for the truck. Ive run kings on tons of vehicles and they have always been right on
I am running the kings with stock rear springs and I love it. I did go with new control arms up front even though it wasn't necessary. It was just so much easier to get it aligned and steering is perfect. I will say that on very high speed hits and bumps the rear bottoms out and kicks a little compared to the front but im talking pretty large bumps at 80+ MPH. For everyday driving and most off road driving this set up is perfect. You will not be disappointed.
I went with SPC from cruiseroutfitters.com.
One other piece of advice- Clearance for the reservoir hose on the front coilovers is very tight in-between the control arm and tire. I think the stock arms would be even tighter. I am using rock warrior wheels with 285/70/17 BFG's and had to use a spacer (spidertrax) up front because no matter how I positioned the hose it rubbed the tire at full lock.
heres some pics for reference:
I'm using Fox coilovers, and I did not lift the LC much - just enough to level it out. I'm using ARB 2720 rear springs. I did new UCAs at the same time because installers say the alignment is easier, and most UCA manufacturers say you get more down-travel with their UCA. I didn't measure travel before and after, but FWIW the shop said the SPC UCAs made alignment a breeze and did increase the down travel vs stock UCA.
Congrats on the new Kings, I had King suspension on my last 2 trucks - great product.
Thank for the info, i am not going to do more than level the LC out at this time, so I wasn't going to do the UCA, but know your guys have me wondering if i should just do the UCA's and be done..
I wa going to use stocks wheels though- i did 275/65/18 already, i was going to move to 275/70/18 BFG's....once i leveled it
Are you having the clearance issues or rubbing on the lines that were mentioned above, on the UCA or wheels?
I noticed this on a friends LC with Icon, he had worn through the lines in 2 areas
Thanks!
I love this input- this is very valuable to me.
