SOLD Orange, CA. 200 series Heritage wheels and 295-70-18 tires.
Trail Rated
CA
$3400
Set of 5 Heritage wheels, complete with center caps, and correct black oem lugnuts.
18x8
5x150 bolt pattern
+60 offset.
With 5 matching 295-70-18
Michelin Defender LTX M/S tires.
No TPMS.
4 tires have 1500 miles on them.
95% or better tread life.
1 tire (spare) has never been used. Still has the sticker on the tread, visible in pics.
Tires date code 20/21
All 5 wheels are perfect, and flawless
No dings, dents, scratches ect.
Wheels and tires are great, I’m only replacing for a move to 37’s.
Local Pickup preferred.
If you want pics of anything in particular let me know.
They are about 33.5” actual height mount on the truck.
They weigh in at 86lbs.
They are quiet and smooth at all speeds.
@Gartenmeister
Rubbing depends on you setup. If you are stock, They will rub.
On the rear I removed the mudflap.
On the front I removed the mudflap, and also pulled the forward inner fender liner, forward more.
Those are the mods I did, And it cured the rubbing.
This is how you list tires and wheels. Great listing, great product, wish you were local - GLWS.
I forgot to mention I have the Tundra front arm swap.
That makes it roughly 1-1/4” - 1-1/2”
wider per side
Same as running a 1-1/4” spacer
That’s what keeps it off the KDSS.
Full turn radius, doesn’t touch the KDSS with my setup.
