One thing leads to another - Geet'n Ready for da Round Up
Austin, Tx
On my journey to get ready for the round up, I started out with 2 things to do. Replace the seal between my NP203 and 700R4 and replace my broken longfield. Yea, only those 2 things.
As I started the tear down and replacement of the seal last weekend. I got it in with some new oil and the interior back together.
This weekend I noticed the front of the traction bar was bent up. I had to cut the old mount off and build a new one from a shackle. I also needed to build another rear drive shaft from some others I have. None of the bolt patterns fit. So I pulled mine off which was very easy because the axle side bolts were loose. I cut and sleeved a piece of pipe and all was good. I then noticed one grease fitting was gone and the other broken off. Put new ones in and pumped some grease in them. Put the new shaft on with blue lock tight on the threads and yes tightened the front drive shaft bolts too.
Shawn came over and we had some fun with his 40, but I'll let him post up on that.
So far I have completed 1 of 2 things for the round up. Stay tuned for the next episode, Goodbye old friend.
I broke my accelerator cable, I know very exciting, but I haven't been able to find a cable that will fit/work so it is currently hooked up with a fishing liter.:crybaby:
Jeff,
How come you're so slow? Don't you have any good tools in Cuba?
I'll see you at the Roundup.
Charles
I'll have it all back together. All I have left, I think, it to R&R the drivers' berf.
load the truck and top off the oil and I m ready see y'all fri night
Jeff you up for Looney toons, Kluniatic, peoples hill, wine and cheese, down back braker, hell and back then Bronco alley run :steer: 4 or 5 same built rigs :steer:
Muahahahahahahaah!!!!
Well, got it all back together. I could not of done it today without David's help. He had some parts left over from the Princess that he gave me. I also had to grind out the knuckle a little for the new chrome moly birf to clear. All I need to do now is load everything up and head out!!!!
Weather is looking great!!! 10 Day Weather Forecast for Mason, TX - weather.com
