Onboard Air (1 Viewer)
Decatur, AL
I have an extra Camry ac compressor taking up space in the garage and was wondering if I could use it for OBA. After looking at the pulleys on the AC pump and the Smog pump they look pretty close to the same size. I know the compressor needs oil but there has to be away to get around that right?
As of right now I have a 12v compressor wired in with a tank under the rear where the spare was, but it is slow and seems to be on its last leg anyways.
Thoughts?
I know with the York compressors (90% certain at least) they have an oil supply inboard to the compressor, and you have to run an oil separator inline after the compressor before your outlet or tank.
I think with modern A/C compressors the lubricant is actually in the pressure lines with the coolant though. Not sure what that'll do to your options.
I've got a york on the shelf that I pulled from a Volvo at the pull-a-part a few years ago that I have been meaning to install, the smog pump spot on the 3fe looks like the perfect place. Keith is right on the oil - I'm not sure what you would do about that.
I have found a couple of threads on YOTATECH about using the stock 3.4 AC compressor. They used the same mini oiler that Matt suggested and then had an oil separator after. I am going to remove the smog pump temporarily and try a test fit when I get some decent weather. So it may be this summer before I get to take a look at it. LOL
I would love to do the York 210 but I already have the camry compressor sitting in the garage and it has the same style serpentine adapter, where the York uses a v belt. Are there any adapters made that mount onto the top of another pulley on the cruiser to drive the v belt? Just thinking out loud on that one, I havent even tried looking it up yet.
I took some time after work tonight to look at the 2 pulleys and the 80 has the v belt pulley and the Camry compressor had a flat belt. So next junk yard run I'll be looking for a York or another Toyota AC compressor with a V belt.
What model did the York come on? All I know is 80s models Combos and some fords
Sent from my Droid thingy using IH8MUD
BOOM!
1963-1968 AMERICAN MOTORS AMBASSADOR
1964-1968 AMERICAN MOTORS AMERICAN
1963-1966 AMERICAN MOTORS CLASSIC
1965-1967 AMERICAN MOTORS MARLIN
1967-1968 AMERICAN MOTORS REBEL
1980-1984 AUDI 4000 5 Cylinder 2.2
1984 AUDI 4000S QUATTRO 5 Cylinder 2.2
1987 AUDI COUPE 5 Cylinder 2.3
1981-1987 AUDI COUPE 5 Cylinder 2.2
1964 FORD CUSTOM
1967 FORD CUSTOM 8 Cylinder
1968 FORD CUSTOM 8 Cylinder 6.4
1968-1969 FORD CUSTOM 8 Cylinder 5.0
1968-1969 FORD CUSTOM 8 Cylinder 7.0
1968 FORD CUSTOM 500 8 Cylinder 4.7
1968 FORD CUSTOM 500 8 Cylinder 6.4
1968-1969 FORD CUSTOM 500 8 Cylinder 5.0
1968-1969 FORD CUSTOM 500 8 Cylinder 7.0
1969 FORD FAIRLANE 8 Cylinder 5.8
1958-1970 FORD FAIRLANE
1965-1967 FORD FAIRLANE 8 Cylinder 4.7
1966-1969 FORD FAIRLANE 8 Cylinder 6.4
1968-1969 FORD FAIRLANE 8 Cylinder 5.0
1968-1969 FORD FAIRLANE 8 Cylinder 7.0
1967 FORD FALCON 6 Cylinder 2.8
1967 FORD FALCON 6 Cylinder 3.3
1963-1970 FORD FALCON
1965-1968 FORD FALCON 8 Cylinder 4.7
1968-1970 FORD FALCON 8 Cylinder 5.0
1967 FORD GALAXIE 8 Cylinder
1963-1964 FORD GALAXIE 8 Cylinder
1968 FORD GALAXIE 500 8 Cylinder 6.4
1968-1969 FORD GALAXIE 500 8 Cylinder 5.0
1968-1969 FORD GALAXIE 500 8 Cylinder 7.0
1967 FORD LTD 8 Cylinder
1968 FORD LTD 8 Cylinder 4.7
1968 FORD LTD 8 Cylinder 6.4
1968-1969 FORD LTD 8 Cylinder 5.0
1968-1969 FORD LTD 8 Cylinder 7.0
1970 FORD MAVERICK
1967-1970 FORD MUSTANG
1963 FORD THUNDERBIRD 8 Cylinder 6.7
1963-1968 FORD THUNDERBIRD 8 Cylinder 6.4
1963-1968 FORD THUNDERBIRD 8 Cylinder 7.0
1965-1968 FORD LIGHT TRUCK E SERIES
1963-1969 FORD LIGHT TRUCK F SERIES
1973-1978 INTERNATIONAL SCOUT II 4 Cylinder 3.2
1973-1978 INTERNATIONAL SCOUT II 8 Cylinder 5.0
1975-1978 INTERNATIONAL SCOUT II 8 Cylinder 5.6
1976-1978 INTERNATIONAL SCOUT II 8 Cylinder 5.7
1968 LINCOLN CONTINENTAL 8 Cylinder 7.5
1963-1965 LINCOLN CONTINENTAL 8 Cylinder 7.0
1966-1968 LINCOLN CONTINENTAL 8 Cylinder 7.6
1960-1965 MERCEDES-BENZ 220 6 Cylinder 2.2
1969 MERCEDES-BENZ 230 6 Cylinder 2.3
1969-1970 MERCEDES-BENZ 250 6 Cylinder 2.5
1973-1976 MERCEDES-BENZ 280 6 Cylinder 2.7
1969-1973 MERCEDES-BENZ 220D 4 Cylinder 2.2
1960-1965 MERCEDES-BENZ 220S 6 Cylinder 2.2
1960-1965 MERCEDES-BENZ 220SE 6 Cylinder 2.2
1969 MERCEDES-BENZ 230S 6 Cylinder 2.3
1969 MERCEDES-BENZ 230SL 6 Cylinder 2.3
1970-1972 MERCEDES-BENZ 250C 6 Cylinder 2.8
1966-1967 MERCEDES-BENZ 250S 6 Cylinder 2.5
1966-1967 MERCEDES-BENZ 250SE 6 Cylinder 2.5
1967 MERCEDES-BENZ 250SL 6 Cylinder 2.5
1973-1976 MERCEDES-BENZ 280C 6 Cylinder 2.7
1978-1979 MERCEDES-BENZ 280CE 6 Cylinder 2.7
1969-1971 MERCEDES-BENZ 280S 6 Cylinder 2.8
1975-1976 MERCEDES-BENZ 280S 6 Cylinder 2.7
1977 MERCEDES-BENZ 280SE 6 Cylinder 2.7
1969-1972 MERCEDES-BENZ 280SE 6 Cylinder 2.8
1969-1971 MERCEDES-BENZ 280SEL 6 Cylinder 2.8
1969-1971 MERCEDES-BENZ 280SL 6 Cylinder 2.8
1961-1966 MERCEDES-BENZ 300SE 6 Cylinder 3.0
1963-1965 MERCEDES-BENZ 300SEL 6 Cylinder 3.0
1967 MERCURY COMET 8 Cylinder 6.4
1975 MERCURY COMET 8 Cylinder
1963-1969 MERCURY COMET 6 Cylinder
1964-1967 MERCURY COMET 8 Cylinder 4.7
1968-1969 MERCURY COMET 8 Cylinder
1968 MERCURY COUGAR 6 Cylinder
1967-1969 MERCURY COUGAR 8 Cylinder
1968 MERCURY MONTEGO
1969 MERCURY MONTEGO 6 Cylinder 4.1
1969 MERCURY MONTEGO 8 Cylinder 5.0
1969 MERCURY MONTEGO 8 Cylinder 5.8
1986-1988 VOLKSWAGEN QUANTUM 5 Cylinder 2.2
OK picked up a 210 this weekend from an old ford. Does anyone have a pattern for the bracket to the 3fe? I still need to de-smog so I have room to mount it.
