Is the ome 863 rear spring the same as slee's SOF2RH.? I am trying to build my own 2.5" kit by buying used stuff. Any help would be appreciated. I will have bumpers front and rear and tow an m116 trailer loaded.
863s will work on everything even 80 series trucks I believe. I would still go with a heavy lift though or a medium lift with air bags. Definitely heavies with a rear bumper. I ran the slee heavies for 1.5 years without a bumper and was fine. Its all relative though. In order to get the proper amount of rake on the vehicle you will have to overload the 863s due to the limitations on the front end. That is why slee developed the 1" shorter version. If you always have a lot of crap in the back of your truck and a rear bumper go 863. if not, go slee. You can also give the guys at slee a call. They are very helpful and knowledgeable. Let them know what you want to do and they will point you in the right direction.
