Hi everyone,
I am having an issue with my Craftsman snowblower. The machine is a 2 stage blower , with a 26 inch cutting width .(http://www.searspartsdirect.com/par...-equipment-Parts/Model-536886281/0247/1507200)
The issue is that at times the engine will bog down hard, almost to the point of stalling out while blowing snow. If I stop blowing snow, the engine will recover and return to normal, then I can proceed again. It does not matter how much snow you are blowing at the time when it happens, it it totally random. Other times the machine will blow the snow without any issues.....all within the same use period. I would also say that the idle is a bit "choppy".
The machine always starts perfectly fine, usually on the first pull. I was thinking there is a carb issue, but if so would it not do it at all times? Any ideas?
Thanks,
Zack
Thanks,
Zack
