Oil change in a 3UR - quick reference
LINUS
Waiting for the Great Pumpkin
PNW - WA
I’m both doing this to inform plus give me ‘sticky-note’ info:
3UR motor oil change with a new filter: 7.9 qt 0-20 oil / — can go 5-20 if towing heavily.
TQ specs:
Filter main cap: 18 ft/lb
Filter cap drain plug: 9 ft/lb
*small O-ring in OE filter is for the stock filter cap drain plug*
If using a aftermarket filter cap AKA Jowett , use the same main cap / flush drain TQ values.
I’ve been running 5w-30 in both my Tundra and LandCruiser for a while and they seem happier - especially at cold idle. I live in the desert. YMMV.
Mostly good; couple changes in that the oil capacity (with filter change) varies by year on the tundra.
Also going from 0-20 to 5-20 is pretty much pointless other than a higher cold starting viscosity. 0-30 or 5-30 is what will make a difference.
-8.5qts (with filter change) of 0w-20 if 2020 3UR or later; 7.9qts (with filter change) 2019 and earlier.
-Good filter tool. TOY640 is excellent, US made, and not expensive.
$26 Assenmacher Specialty Tools TOY 640 Oil Filter Socket Wrench for Toyota/Lexus
https://www.amazon.com/Assenmacher-Specialty-Tools-TOY-640/dp/B0015PK3AG
-Toyota 04152YZZA4 filter kit pay attention to how the housing gaskets fit
You will need a 24mm socket to use the above tool. You will also want a torque wrench.
OEM drain plug fiber washer.
Filter housing drain cap- 9 ft/lbs
Filter housing- 18 ft/lbs
Drain plug- 27-28 ft/lbs
