OEM switches backlighting
Tucson, Arizona
I’ve got a1990 HDJ.
My OEM switches for my antenna up, center diff lock, rear defrost, headlight washer, and factory foglights do not light up with my lights on…the only one that does light up is my antenna down.
I have pulled each switch out of the dash, but don’t know if I can pull the actual switch apart to replace the backlight bulbs or if I have to replace each switch (?)
Thanks in advance.
Bulbs should just 'screw' in.
This thread is for LEDs but you can see the type of screw in bulbs that are used in various switches
cheers,
george.
