[NV] 3FE engine/trans parts for sale
I'm parting out my 3FE engine and have most parts on it -- with the exception of the crank, AFM and rubber intake hose (those parts are no good). I'm keeping the alternator, power steering pump and A/C compressor.
Posted this a few months ago and sold some parts -- trans cooler lines, fan, AC bracket, mount, smog pump, ECM, distributor. I believe I still have everything other than the ECM needed for a 2FE conversion. Head is in good shape, I lapped valves and installed new stem seals.
I also have the A440F available. Didn't have any problems with it, but it's got 237K on it. California truck, no rust whatsoever.
Engine and trans are pulled and ready. But note that I'm ONLY parting out engine and transmission at this time. Make me an offer on what you need!
I need distributor 19100-61102
what are you asking for the complete head?
3fe parts
I need one of the end braces for the intake manifold, # 17125
Hi truckin1975,
Sorry to hear you're stranded! Do you just need the top or the whole unit? Do you need any of the sensors/switches?
Note that herbigp above just asked about it as well (what are the chances) too. In all fairness I should go with whomever buys first, though maybe herbigp can defer to you in your situation?
Shane
thermostat housing
i need the bottom half of the thermostat housing that bolts to the block. thanks kevin 423 782 8376
i don't think i need any sensors or switches, but you can quote me on the bottom and the entire unit. thanks again. kevin
3fe thermoststat housing
I need the bottom. I sheared the bolt off on the lower portion, everything else I have is good. I thought I PM'd you too.
98365 if you still have it?
Thanks
please email me if still available
patherbig@gmail.com
What do you want for the A440F? I am also in Reno so no shipping req'd
