SOLD North Florida 2005 Lexus GX470 Full Lexus Service
Year
2005
  1. GX470
Gainesville, Florida United States
Mileage
299200
Color
rgb(20, 19, 101)
2005 GX 299k. Full Lexus of Palm Beach dealership service since new with all service records available. Clean title, always a Florida truck that has never seen snow or salt with zero rust. No cracks on dash. Paint has some scratches but no clear coat peeling. Drivers seat and steering wheel show wear from normal use. Heated seats, dual climate control, touchscreen, navigation all working. Sunroof is the only non working item. Oil pan weeps some oil, no other leaks. Bfgoodrich tires in good shape. Owned by non smokers.
Recent services from Palm Beach Lexus include:
New power steering pump 299k
New high pressure lines 299k
New Lexus battery 299k
New Lexus alternator 299k
New valve cover gaskets 292k
New O2 sensors 292k
4 wheel alignment 291k
Coolant flush 291k
New Rear suspension airbags 288k
Transmission replacement 264k
Rear main seal 264k
Timing belt 264k
Water pump 264k
Thermostat 264k
Drivebelt 264k
Hood shocks 264k
Front axles 175k
New brake pads 175k
Turn rotors 175k
Message me with any questions or for any pictures you’d like to see. $6900
ChatGPT: :rofl:
Based on the information provided, the 2005 Lexus GX470 with 299,000 miles appears to be well-maintained and in good condition, considering its age and mileage. It is a positive sign that the vehicle has been serviced exclusively by the Lexus dealership, and that all service records are available.
The recent services, including a new power steering pump, high-pressure lines, battery, and alternator, are all important maintenance items that suggest the owner has been proactive in maintaining the vehicle. The replacement of the valve cover gaskets and O2 sensors are also positive indicators of maintenance.
The fact that the vehicle has had a recent transmission replacement, along with a new rear main seal, timing belt, water pump, and thermostat, is also a good sign as these are major components that can be expensive to replace. The replacement of the drive belt, hood shocks, front axles, and brake pads further suggests that the owner has kept up with routine maintenance and necessary repairs.
The cosmetic issues with the driver's seat, steering wheel, and paint are not uncommon for a vehicle with this age and mileage. The non-working sunroof is also a relatively minor issue.
Overall, the 2005 Lexus GX470 with 299,000 miles appears to be a well-maintained and reliable vehicle, given its service history and the recent maintenance performed. However, it is always recommended to have a pre-purchase inspection performed by a trusted mechanic to ensure that there are no major issues that may require costly repairs in the near future.
Did the dealer put in a brand new transmission?
-Chris
Yes new trans. Service reports say there’s an issue with the transmission - also states remove and replace the transmission and reseal the Rear Main plate and both seals.
