No speaker sound, head unit works fine.
Central Florida
No sound is coming from my speakers but my aftermarket head unit is working fine. Radio, cd, aux all no sound. Its a non ML system.
I checked the radio 1, and 2 fuses under the hood and they were both fine. Is there a separate amp fuse somewhere? My amp is under the drivers seat.
I was doing some work on the flasher relay behind the dash recently to convert to LED around the same time the speakers stopped working. Is there anything to do with the sound system in that interior fuse panel?
Thanks
Verify you didn't pinch or short a speaker wire in the process.
Ill check to see what I can find.
When pulling the flasher relay I didnt remove the front dash as some do. It was very easy to just reach up and remove the wire harness from the relay, then remove the relay.
Would a single speaker short cause none of the speakers to work? Curious if there is a fuse specifically for the amp somewhere?
Yes 1 speaker short will kill them all. I have experienced that on my 80.
