no hazards or indicators
New Zealand
re wiring my bj44 which is 12volt. have no indicators or hazards. I have my hazard switch out and i get power to green/white and green/orange when the switch is in on position, and that is it. From there i don’t get any power to the flasher relay.
below is diagram i am using . any help is appreciated
I ran a bead of good hardware-store caulk across my cowl seam, covered it with gray rattle can enamel applied with a paintbrush. It keeps the hazard switch dry. Internally, it needs cleaning.
Although probably unrelated, if it is a right-left discrepancy, it probably is a bad ground on one of the lamp's chassis.
just noticed that mine is 24v stamped . would this be the problem? cleaning contacts did not help. cheers
just compared part numbers and diagrams, and yes they are different parts. case closed . thanks
do u need the Correct HAZARD Switch for your BJ44 12V ?
if so PM me
i have the correct one for a NON-USA Application .........
matt
