You bet. It's called a dummy load.
Antennas that are designed to transmit and receive on multiple bands typically do so on frequencies that are harmonically related. For example, the 70cm band is roughly the 3rd multiple of the 2m band. A 2m/70cm antenna will do fine for receiving wx radio and two-way radio in the 450 and 800 MHz bands. It won't do a very good job of receiving at CB frequencies and will not function as a transmit antenna on CB without a tuner of some type.
Since it sounds like you want to run multiple radios (CB, scanner, 2m/70cm HAM), a better solution would be to connect each to a seperate antenna. It would also be cheaper, since only the CB and HAM antennas need to be capable of handling transmit power.
73
Bob N5UOU
