New Differential Drop Kits
Marlin Crawler
Supporting Vendor
Fresno CA
Website
www.marlincrawler.com
IFS Differential Drop Kits
MarlinCrawler.com/products/differential/differential-parts
CV shafts in a bind? Vibration getting to you? Then you need to relax your front CV shaft angles with our differential drop kit!
By fitting our 1-inch spacers between your front IFS differential brackets and sub-frame assembly, your differential axle centerline is lowered by 0.39″ resulting in reduced axle joint misalignment and CV boot wear for longer lasting performance with less harshness.
An easy way to improve IFS axle longevity! Available for 1995 and newer 4WD Tacoma/4Runner/FJ Cruiser/GX applications and proudly made in the USA!
Skid Plate Drop Kit
MarlinCrawler.com/product/skid-plate-1-2-drop-kit-type-2-3-4-ifs-1995-2024
After installation of our Differential Drop Kit you’ll need to lower you stock or aftermarket skid plate as well. This is due to the differential components possibly contacting the skid due to the change in geometry. Our 1/2″ drop will space your skid plate down giving you the clearance required to reinstall.
Proudly made in the USA!
Offset Differential Bracket
MarlinCrawler.com/product/offset-driver-side-differential-bracket-for-type-3-4-ifs
We are now stocking Genuine Toyota off-set style front driver-side differential brackets for Type 3 & 4 IFS frames!
RCLT HD customers running Prado 150 SUV frames will notice this bracket because it's a required component in order to fit our oversized MarRack upgraded HD steering rack into the smaller SUV frames as discussed on Page 13 of our RCLT HD Install Guide.
Now available at Marlin Crawler!
