Need wiring diagram 79 series
Zimbabwe, Africa
Cheers, from Zimbabwe,
Need underdash wiring diagram. If anyone can help me I have two 79 series, clock & radio not working. Kick panel fuse o.k., earth o.k.. Comes on now and then so assuming bad connection, just need to know what and where to look. All other electrical working o.k.
Hello,
A little more information is necessary: model year, engine type, gasoline/petrol or diesel...
It may be a chafed wire in contact with a body panel. This unwanted ground prevents the radio from working. Not sure about the clock.
Check the dash underside for chafed wires and loose harnesses. If you have power windows/locks, check the wiring as it passes through the grommets.
Hope this helps.
Juan
Hello,
Hope this helps.
Juan
Hi Juan,
Two cruisers 79 series 2001 & 2002 Bakkies diesel 1hZ. Earth is good, positive wire is dead. All fuses 100%. This is a supply problem some where between fuse box out and split to clock, radio, cigarette lighter. No power windows. Checked as much as I can see just need color code to trace.
