Upon removing my carpet I found some small rust holes on the drivers side next to the large access hole. I chiseled up some of the tar and there were more holes under there. I was disappointed for this is the only rust that I have found. I checked the same spot on the passengers side and it is perfect. I have run a hose all over and can't find out how water is getting in there. The worst of the rust is on the backside of the metal. I think it is somehow running down the seam that is on the right in the second picture. I also went underneath and removed some of the undercoating where that pocket is welded on and there is rust all around that seam also. Does anyone have any ideas to where the water is coming from? What is the best way to fix the rust? It doesn't seam that cutting it out would be very easy without taking the body off because it mounts to the frame right there.
