TrickyT
Hate that mud...
I need suggestions on how to remove the valve lifters on my 1989 3FE. I've got the rocker shaft assembly and push rod cover removed, but the lifters won't come out. The lifters move freely in the block, but when I try to pull them out I can't. This engine has 200K miles on it and there's a lot of varnish build up on everything. I suspect that there's a "lip" of varnish built up on the sides of the lifters where they stick down below the block casting that's preventing them from coming out. Any ideas? I could pull off the oil pan, but I don't think there's any way I'll be able to get to the bottom of the lifters with the camshaft in place, and I can't remove the cam with the lifters in. So I'm pretty baffled on how to proceed.
