moly grease
vancouver island
So i'm right in the middle of my knuckle rebuild and do ya think i can find moly-lithium grease anywhere. No.
Not at can tire, not at napa, no local auto store they all look at me like i have 5 heads. Toyota well "we usually have some around" but not today i guess.
So do i do the whole job with reg wheel bearing grease or do I drive like 120km to find this s***.
Anyone only run reg wheel bearing grease?
Frustrated on vancouver island
I wouldn't get all bent out of shape if you can't find that exact type of grease. There's got to be some moly fortified grease or grease with at least some moly in it somewhere near you.
I like using Lupriplate No. 3000. I know Lordco carries it. Talk with your local auto partes and see if the main chain can access...
http://www.lubriplate.com/Products/greases.htm
gb
Caterpillar part number for 14.50oz tube... 5P-0960
16oz tub...129-1922
5 gallon pail- 7X-7699
Good luck!
-Steve
The moly grease only insures that everything wears together properly and quickly, I think?
right?
I can't see any harm in not using it but make sure you use really good bearing grease
Canadian tire, Its in tubes, its called extreme pressure grease for cv joints and such. its moly based and black in colour.
right?
For a good grease primer try this:
http://encyclopedia.lockergnome.com/s/b/Grease
http://tsikot.yehey.com/forums/showthread.php?t=8987
http://tsikot.yehey.com/forums/showthread.php?t=8988
There is a reason MP grease is spec'd for the wheel bearings and Moly base for the high pressure areas like the Birf and knuckles.
I prefer a Moly EP grease for the knuckle bearings, and outer axle, however some grease is better then no grease, and there are many who will use a MP wheel bearing grease for the knuckle bearings, birfield, and knuckle cavity.
I suppose if I were going to go by the book I should really use the Moly/Lith No2...
I would not however use an EP moly for your wheel bearings.
gb
Amsoil makes synthetic moly fortifed greases.The logging types here really like it for extreme load applications (all the time for them).
Cheers Stephen
thanks poser i went to the cat dealer and picked up a bucket. That should last awhile.
Now if i could only get the bottom bearing race in
...................................ahhhhhhhhhhhhhh..............
lmao
