If you are not going crazy cutting all kinds of stock/angles, go to Lowes or Home Depot and buy a basic single compound 10" miter saw. Ou you can get one real cheap. If you decide you are going to need more saw later, move up and put a steel cutoff blade in the basic one. 12" compound sounds way overkill for what you describe.
Unless you plan on doing a whole ton of crown, base, & door trim on a regular base, go spend 150-200 & p/up a 10" Delta or equivalent.
No reason to get a 12" unless you need it. The saw itself is more expensive, bigger to stow, and heavier to carry. The blades are also twice as expensive.
