And yes. That pump could be moved to the drivers side. Georg has a bracket.
I have to say, she has been responsible for more of my vehicle purchases then i have. She loves the community and she loves the pig. Only downside is where most guys wives are their check valves, mine usually wants to know if we need 2.![]()
@RUSH55 I hadn't really thought about the length of hose for the power steering, I will have to look at that. And on the oil filter, I noticed that as well, and it has definitely been that way for a while. From what little reading I have done, I suspect that was done many years ago to get rid of the cartridge style filter. I am still learning, but I will get some better pictures of it later today. I do agree it is definitely going to make a mess given its angle and location.
As far as where the PS pump is mounted, there is a bracket bolted to the front of the head that may have had something still in it when the PS conversion was done that would have prompted the PS mount, but I have no idea what that bracket may have held or when it would have been removed. If anyone knows what that curved mount would have held, I am certainly interested. And if someone needs it, let me know as I am clearly not using it.
That curved mount is for the much needed factory air cleaner to get rid of that horrific rectangular object.
All projects for AFTER the Swine Soirée
Hide your wallet if your saying rubber parts near a pig...just sayin’
So I believe we found the culprit to my squel. Pulled all the adapters off and found what we think may have been the original carb gasket under the bottom of the stack. Flat, flat and hard as a rock. The other two were still a little pliable.
Note the discoloration, that is the side that the whistle was coming from.
So i am going to pick up some gasket material tomorrow. Also found that someone stripped out one of the holes in the middle adapter. So I also need to pick up a longer bolt to try and to make it down into the good threads left in the adapter plate.
Anyway, we also did a little filing on this washer too because it appears that it may have been keeping the base plate from seating properly.
Can anyone tell me what that bolt is for? Is it part of the original carb mount or something else?
Also, here are a couple pics of the homebrew pump bracket. The bracket bolted to the head was torched out. The actual pump bracket looks like it came off something else and was modified to bolt onto the side of the head. The hoses are crazy long and I do think I will check on that bracket from Georg to move it to the drivers side.
And does anyone know if these grommets are available. Lots of holes in the firewall that need plugging off.
And is there a good source for door seals and other rubber parts?
I’ve used Seals-it ( Seals-It – Industrial Seal Manufacturer CT – CT manufacturer of seals for the auto industry. ) seals and grommets on several projects and their quality and selection is second to none.And does anyone know if these grommets are available. Lots of holes in the firewall that need plugging off.
