I used a long flexible adapter on a drill with a wire brush to knock scale off and then used an Eastwood spray can rust coat product that came with a long straw and a nozzle that sprayed sideways. I will see if I can find it on their site. I will need it again. I also used it on the inside of anything I could not otherwise reach - door pillars, inside the frame, etcI want to coat the inside of the doors with something....does 'mud have a good recommendation? I've been looking at the Eastwood products and they look good. I still have quite a bit of scale to work with on the inside of the doors that I'd like to neutralize.
Here is a trick that I learned from the YouTube. Instead of cutting out a patch panel and trying to butt weld, tack weld your patch right over the skin that needs to be replaced.
Then start cutting right along the edge of the patch panel but cut at a 45 degree angle and only about 6” at a time.
then as tacks release, slip the new panel down into the old metal a little at a time and re-tack it in flush with the original metal.
work your way around taking your time and keeping it cool and you don’t need clamps or need to worry about poor cuts or warping the panels.
I’m glad I just found this thread and didn’t have to wait 3 years between progress postsView attachment 3705037
A PO at some point cut the rear frame rail out to make room for this rear tank. The rear is boxed in with these monster steel angles, which the tank nicely tucks into. I don’t mind the fuel tank in the back and I’m sure the frame is as structurally strong as original with as much steel is back there.
Gotta decide what to do with it. I plan on a built swingout tire carrier that I can fab anyway, and I can work with this. Or cut it all out and go back to stock fuel tank under the passenger seat, and try to source a rear frame rail from another truck to put it back together. Hmmm.
