Many products Now Back In Stock @ MarlinCrawler.com!
Marlin Crawler
Supporting Vendor
Fresno CA
Website
www.marlincrawler.com
The following great products are now back in stock!
4.70:1 Low Range Gear Kits
  • 21- & 21-spline
  • Most successful, decorated, technically advanced and longest lasting low range gear sets on the market
  • Durability proven with the most podium finishes in competition events with zero failures
  • Made out of Chromoly in Japan by Toyota's own gear cutter
2.28:1 Turbo Input Gear
  • Designed around our Total-Spline technology
  • Strongest gear drive t/case input ever made
3.12:1 80-series Land Cruiser & Lexus LX Gear Kit
  • Provides a 25% reduction
  • Increases low range torque for heavy Land Cruiser builds, makes the vehicle feel lighter and more nimble
  • Increases engine compression braking, requiring noticibly less braking on descents
Axle & Knuckle Service Kits
  • High quality Japanese sourced parts
  • KOYO and Nachi wheel and knuckle bearings
  • 1979-85 Pickup/4Runner Axles & Knuckles
  • 1976-89 Land Cruiser Axles & Knuckles
  • Our industry-first EcoSeal Heavy Duty axle seals available
Wheel Bearing Kits
  • Front and Rear Kits available
  • Available EcoSeal Heavy Duty Rear Axle Seal
  • Pickups, 4Runners, Land Cruisers
  • IFS Bearing Kits also available
80-series Land Cruiser and Lexus LX Steering Upgrade Kits
  • Upgrade to stronger DOM steering links with new OE Japanese-made tie rod ends!
  • Proper, factory-style steering stabilizer mount instead of cheap "u-bolt" designs
  • Japanese ends, USA-made DOM tubing
Long Spline Drive Shaft Kit
  • Upgrade to a full 8" of drive line travel
  • Really nice kit with High Quality, Japanese-made extended length slip joint
  • Japanese-made High Quality U-Joints
High Quality Japanese U-Joints
  • We only offer High Quality Made In Japan U-Joints
  • Proper strength and quality that prevents U-Joint faliure out on the trail
  • Much higher quality than over-the-counter auto part store offerings
  • Great to carry as a trail spare
LCA Frame Brace Kit - Improved design!
  • We have improved the design for 2005-2015 2nd gen Tacoma applications!
  • Now a precision fit over factory Cam Tabs without having to choose which gap to average
  • If you've been eyeing this kit, now's a great time!
MarlinCrawle.com
