LX 570 Harrop Supercharger Stage 1 and 2 Impressions
Welp, I'm stage 2 now. Tuned using HPTuners.
513 all-wheel hp
563 all-wheel torque
9psi per boost gauge
80mm pulley
ARH long tubes with cats, stock LX exhaust
Prospeed fuel system
Mustang Dyno MD-AWD-500
That’s all the information I need 👌🏼
…well, except, what would stage 3 do 🤔
513 all-wheel hp
80mm pulley
Might be worth updating the thread title.
Impressive numbers all around.
You show a 1 second improvement in 0-60 and that carried through the 1/4 mile. I would think there is a bit of meat left on the table. Is it banging the limiter at the top of 2nd? Look at Viktor G YouTube channel. He explains some stuff about HP tuners in Tundras with the same power train. I think you could be into mid 12’s with a little more work on that tune.
You’re right, there are improvements that can be made with the shifts, particular the 1-2 shift, very slow.
So I do own the Magnuson airbox lid from the Tundra supercharger kit. I purchased it from superchargersonline.com. The lid fits on the airbox base just fine, and the 1/2 inch larger diameter of the hole is noticeable. The issue I had was the air pipe/coupler included with the Harrop kit wouldn't stretch over the larger hole on the Maggy lid. I even tried silicon spray lol. I never got around to sourcing a larger coupler. Also, about about the MAF sensor itself? Doesn't that have it's limitations?
Increasing the tube size is a viable strategy to increase metering bandwidth. Make sure it's scaled in the tune. Otherwise it's a hack that can backfire as it causes the ECU to believe there's less air. Causing things to potentially run leaner with more timing.
513 all-wheel hp
80mm pulley
😎 looking at other dyno #’s of loss of power thru drivetrain that’s ~630hp at the crank. Does that seem about right? Either way pretty impressive.
Planning to go with Harrop Stage 2 once we’re able to unlock/tune the 2016+ ECUs. Does anyone know if HPTuners has this capability yet?
Last spoke to prospeed in Houston a month or two ago and the answer was no. And they reiterated “no tune needed”.
They did say that they might “take a crack at it” or something salesy sounding that didnt win me over.
They are reputable though from what I know.
I vaguely remember there may be a substantive difference between 16/17 and 18+ with regard to encryption and tuning ability. A few other things changed in 18 so a software/firmware change as well is plausible.
Also note that HPTuners says some Toyotas work when same year Lexus doesn’t.. (2013 specifically) which may point to things not working for a late model LX (Mal) but a cruiser being an option (maybe).
Personally I’d get on the phone with different shops to explain what you are looking for and see what they say. Tuners are constantly evolving their craft and what wasn’t an option last week could turn into one today.
The idea is trying to make these flexy school busses fast is wild to me.
Its called stuntin son. Lol.
Im just trying to replicate a G63 though at the end of the day. And those don’t drive nearly as comfortably as the LX. Im holding off until a tune is out for me, and even then i may just not.
But the idea of having it all without too much worry is more possible here than anywhere else IMO. And im comforted by the fact even T did it at one point.
There is an escalade V out now too. I would be lying if i wasn’t drooling at those. Its 💲💲💲 though.
It is all wild at the end of the day like you said.
One day I'm gonna get someone to make a huge NA engine and drop it in a 200 series. I like having options on the road. Being stuck on a country two lane behind a train of cars gets old
Agreed. My wife sold her GX470 and has a AMG GLE63S. It’s crazy fast! Trying to match that seems insane. Maybe a stage 2 and re-gear will get it there.
I took my ‘18 to a local Denver shop to try to pull a file and it was no-go. They said they actually work with Prospeed and have a car they send back and forth and work on/race together.
I may end up having a shop weld in a bung into the exhaust and put a sensor in it and throw it on a dyno to make sure it’s staying in a safe A/F ratio. Of course testing at 5,280 and then me regularly driving at 10,000ft+ and towing 8k# is another story. Nothing is ever 100% without a tune, but it’s insurance and life is short. No ragrets
Agreed. My wife sold her GX470 and has a AMG GLE63. It’s crazy fast! Trying to match that seems insane. Maybe a stage 2 and re-gear will get it there.
Great to know. This is an LC right?
Thats what prospeed was telling me, they may be able to read it. Glad i didnt get too excited.
I'd run EGT as well personally.
Since timing is another critical part of tuning for forced induction, and any maps the stock ECU tries to adhere to will be based on NA spark tables, you're already at a disadvantage even if the fuel can sort itself out.
But I'd also not run a SC when a real tuning option isn't available. Call me conservative. Then again that's also why I drive a J-series.
Harrop has a good description of their approach to tuning in the tech guide on their site. The fueling approach seems very robust. Timing is another issue. They tested with 98 RON which I believe is ~93 Octane. I can't get 93 regularly.
I agree with bloc. There's simply no way I'd ever run forced induction without a proper tune. I could care less what Harrop says, they've got a direct conflict of interest. The stock ECU has no idea you're jamming down a whole bunch more air and it simply can't compensate properly on the fuel/timing maps. It might be able to compensate on the fueling using the MAF, but that'll hit its upper limits and then the ECU won't know how much more fuel to add from there.
Even on my cars that have factory forced induction, once I've changed something major, like going to larger turbos, they needed a completely new tune. To take an engine that's NA, add forced induction and not add a tune to make it run properly is just insanity.
Agreed. And even if it doesn't run up against MAF limitations it will not use A/F ratios appropriate for boost because without a tune it doesn't know it needs to. This is also my issue with their strategy for spark tune.
What harrop does is not a tune.. it's a band-aid.
