Does anyone have the sequence? Is my low tire passenger front?
As an aside:
If your TPMS system is triggering at 33psi, it means you have your system initialized to 44psi (System triggers at 75% of set pressure). If 44psi is correct for your tires, then why are all the other pressures so low?
HTH
Thank heavens we have some abnormal humans on Mud to help out.Because no one noticed the tires where low until the sensor went off? Most normal car tires are around 35 psi so even if you do check the pressure and it reads 36 you think your good to go. Some folks just don't know the difference with larger tires on a heavy SUV or how to read the info on the tire. It's all greek to the normal human.
